SolaraGuy.com • View topic - FS Feeler: TRD Oil Cap
Postby Mr_Chunkz » Fri Sep 12, 2008 11:46 pm
I have a brand spankin new TRD Oil cap
This TRD Oil cap was only opened, emblem was applied and attempted to put on the car....
Then I realize a 1mz fe only takes the TWIST style oil cap... and not the SCREW style oil cap
so basically Im at the mercy of the ebay seller for my own stupidity
If they dont refund it would anyone be interested? If so how much?
FYI: From the applications listings I've seen online this cap should fit 2az motor ( it says compatible with TC )
It also says ALL TOYOTA SCREW ON OIL CAP TYPES
So basically if you screw on your cap this will probably fit? If you do a half circle twist then pull this will not fit.
Heres some pics...
Sorry for the bad webcam shots my digi cam is outta batts right now
- Mr_Chunkz -
The Daily
Mr_Chunkz
