SolaraGuy.com • View topic - WANTED. SOLARA DOOR
WANTED. SOLARA DOOR
WANTED. SOLARA DOOR
Postby tropicalshoes » Fri Dec 26, 2008 12:11 am
I have a 00 solara, and i wrecked it like 2 years ago on a pole, and since i'm going to have the car for awhile i'd love to fix the drivers side door, post up what you have laying around ..
I think a 99-01 door would fit too.
Thanks you all :)
.sarah.
tropicalshoes
Postby Gangis » Fri Dec 26, 2008 8:14 am
Pretty sure an 02-03 would fit too, but the inside trim would be different as they switched to mustard wood for 02. Look around in junkyards.
Gangis
Postby aleki2424 » Fri Dec 26, 2008 8:53 am
Dpnt have one But ^^ i think he can just switch out the trim with his 'old' one depending on the amount of damage, and thus not have to worry about matching trim.
aleki2424
Postby SpeedySolara » Fri Dec 26, 2008 11:09 am
If you wrecked it like you say, make sure the car is safe to drive and that it only needs a door and not some frame work.
SpeedySolara
Postby rewmomi » Fri Dec 26, 2008 1:37 pm
dude i saw a black solara with only front end damage at the junk yard a couple days ago. it was craxy rays down on route one between laurel and elkrigde i believe.
rewmomi
Postby CorCamrySE » Fri Dec 26, 2008 2:36 pm
its prob stripped clean now if its at the laurel location....i hate that crazy rays so i usually go to the one down in hawkins point
MCV30 - 1MZ-FE
2003 Lexus ES300
CorCamrySE
Postby tropicalshoes » Fri Dec 26, 2008 3:58 pm
aleki2424 wrote:Dpnt have one But ^^ i think he can just switch out the trim with his 'old' one depending on the amount of damage, and thus not have to worry about matching trim.
My Dad already fixed it up to the point where it can drive, I just should replace the door because it's starting to rust up pretty bad and the air comes in through the window and makes some noisy ass noise. :)
.sarah.
tropicalshoes
Postby ptballer » Sat Dec 27, 2008 4:14 am
where are you located?
ptballer
Postby tropicalshoes » Sun Dec 28, 2008 5:20 pm
Louisville, ky.
.sarah.
tropicalshoes
