SolaraGuy.com • View topic - CHEAP!! FS 6 Brand new Denso IK22 spark plugs
Postby RichD978 » Sat Mar 07, 2009 10:23 am
These are around $16 each. I have 6 brand new for $65 shipped
Priced to sell
Until recently, platinum was considered the best material to use on the top of an electrode because of its durability. However, Iridium is 6 times harder, 8 times stronger, and has a melting point 1200 degrees higher than platinum. Put that into a harsh environment such as an engine piston chamber, and you have a spark plug that can resist wear much better than platinum. Additionally, the DENSO Iridium Power alloy is so durable; it allowed our engineers to produce the world’s smallest center electrode (.4mm) which reduces the voltage requirements, concentrating its sparking power. Also, its smaller size, combined with the tapered U-Groove ground electrode, allows more room for the flame kernel to develop and produce a more efficient combustion.
RichD978
Postby LatinUSMC » Mon Mar 09, 2009 12:22 pm
i need to do spark plug change soon..are these for a my 01 4 CYL auto 5sFE???? is so ill buy them//any one know?
LatinUSMC
Postby Mr_Krispy1183 » Mon Mar 09, 2009 12:36 pm
^Josue, IK20s would be more suited to you.
Postby Midias » Mon Mar 09, 2009 12:46 pm
LatinUSMC wrote:i need to do spark plug change soon..are these for a my 01 4 CYL auto 5sFE???? is so ill buy them//any one know?
I just got a set of 4 NGK irridium IX plugs for my wife's 5sfe at advance auto parts for 26 dollars. Just a heads up sense his are not as good for your 4cyl and would better for a v6.
Just a heads up for the seller ik22 run about 8 dollars each online
