SolaraGuy.com • View topic - Eric Sol BBK
Eric Sol BBK
Eric Sol BBK
Postby Sp33d » Mon Mar 23, 2009 11:28 pm
I made a batch of ten back in august and still have one set left.
selling 160 shipped. paypal is mark_huynh@msn.com
-Mark
Sp33d
Postby Gibson99 » Wed Mar 25, 2009 7:54 am
What all comes in the kit? Pics? I've only read small bits here and there about this ericsol kit, and have never seen one. What's involved in installation, and are any other parts needed?
Gibson99
Postby sydemoid » Wed Mar 25, 2009 8:03 am
You're going to need new rotors from a MK4 Supra turbo, 13.5 inches, the ericsol kit, is a relocation adapter, which allows the stock brake caliper to be mounted further out, thus allowing you to use a bigger rotor, which in turn increases brake torque.
This provides a bg advantage over a stock system, I personally recommend goodrich steel braided brake lines, and an upgrade to DOT4 brake fluid, as well as either metallic, or carbon metallic pads for you to notice serious gains. ;)
sydemoid
Postby Gibson99 » Wed Mar 25, 2009 8:36 am
OK, so what is the new minimum wheel size? 16 or 17? Can you use Supra calipers with those rotors? I bet there's more, better brake pad options for the supra calipers than for any camry/avalon/etc caliper, plus it's probably a larger caliper.
I already have goodridge SS brake lines and DOT4 fluid - ATE blue actually. No complaints when paired with Axxis ultimate pads, even in stock size. Then again, I don't know how brake fade will be with these pads if I ever take it out to the track. On the street it's nearly as good as my miata... but the miata has carbotech panther plus pads in front and axxis ult in back... and stock brake lines... but it also weighs 1000 lbs less. :)
Gibson99
Postby Eye8Pussies » Wed Mar 25, 2009 9:11 am
you still need 17" wheels to clear the brakes
Postby trdkamuri51o » Wed Mar 25, 2009 9:21 am
bump for a good seller.. i have this kit on my car and im soo pleased wtih the braking performance..
its a huge increase that i saw straight out
i tested the difference in braking before and after (4cyl)(v6 brakes)(supra rotors now) and there is a noticeable difference in the distance to stop..
gibson if you get it the minimum wheel size is 17"
that means a spare of that size too..
trdkamuri51o
Postby corlon » Wed Mar 25, 2009 10:52 am
pm'd and paid.
NiCe
corlon
