SolaraGuy.com • View topic - WTB: Aftermarket Hollandia Sunroof
Postby LEE337 » Wed Jul 22, 2009 10:32 pm
Well Ive had no luck finding an aftermarket sunroof. Maybe yall can help me out. Ive been through junk yard after junk yard with no luck at all. I do know that Hollandia was bought out by Webasto. Im not sure if thats why its so dam hard finding one or not. Any info will be much appreciated. For now Ive been driving around like this, with my eyes on the clouds.
Postby yaddadaimsayin » Wed Jul 22, 2009 10:39 pm
GHETTO!!!
Postby LEE337 » Wed Jul 22, 2009 10:54 pm
yeah I know, but what choice do I have???
I have more important problems with custody over my daughter and she will always come first.
Postby Ilovemylara » Thu Jul 23, 2009 10:36 am
I bet you could remove that entire assembly, and put a oem one in there.
Postby LEE337 » Thu Jul 23, 2009 8:59 pm
Thats a bet you would lose. Thats the first thing i tried. The oem's are bigger than the aftermarkets.
Postby prsolara » Thu Jul 23, 2009 9:18 pm
^^ you can go to a body shop and tell them to close the sunroof (I mean no sunroof) you can do it, although I think is a little bit expensive. I tell you this because I see a car in the body shop where is my car right now and they do it.
prsolara
Postby ToyoSolV6 » Thu Jul 23, 2009 10:22 pm
Damn Lee that thing is beging to Rust.
Postby LEE337 » Fri Jul 24, 2009 5:28 am
prsolara wrote:^^ you can go to a body shop and tell them to close the sunroof (I mean no sunroof) you can do it, although I think is a little bit expensive. I tell you this because I see a car in the body shop where is my car right now and they do it.
To close up the sunroof would involve a lot more money than a new sunroof. What I may end up doing, if I cant find an aftermarket one, is get a sunroof place to cut a little bit bigger hole to fit the oem one. If they can cut the hole then I could install the sunroof. Thats just a thought and Im not even sure thats possible. Im thinking its gona cost about the same or even more than just covering the hole.
ToyoSolV6 wrote:Damn Lee that thing is beging to Rust.
Yeah, it looks that way huh. Its not rust, its the old POS seal.
Im not sure why it looks like that, but the area you see that looks rusted is not even metal.
Postby LEE337 » Sun Oct 04, 2009 12:35 pm
BUMP!!!
I really need a new/used aftermarket Hollandia sunroof.
Anybody know where I can get one.
Ive been all over the net tryin to find one.
Anybody??? :puppydogeyes:
Postby kpxboi0619 » Sun Oct 04, 2009 12:41 pm
get a big piece of fiber glass, tint that cut it and put it and use epoxy to glue it down :)
kpxboi0619
Postby wkbrdr91 » Sun Oct 04, 2009 12:47 pm
I'm hoping your not just leaving your car out with no covering... What I would do is buy some type of clear plastic type thing (like a wrangler soft top window) and tape it up for a temporary fix.
2006 Solara Sport
wkbrdr91
Postby LEE337 » Sun Oct 04, 2009 2:52 pm
kpxboi0619 wrote:get a big piece of fiber glass, tint that cut it and put it and use epoxy to glue it down :)
I thought about that, but if I did then it would be a b!tch to remove if I ever did find a sunroof. I may end up doing that till I get the money to seal it back to not having a sunroof at all. As in get a bodyshop to put it back the way it was before the sunroof was put in.
My other option would be to have the hole cut a bit larger to fit the OEM sunroof. Which boggles my mind on why they didnt put an OEM in there in the first place.
wkbrdr91 wrote:I'm hoping your not just leaving your car out with no covering... What I would do is buy some type of clear plastic type thing (like a wrangler soft top window) and tape it up for a temporary fix.
Oh, of course.
I have a car cover for my Lara w/3 coats of scotch gaurd on it just to make sure nothing gets through.
Postby solara90 » Sun Oct 04, 2009 3:16 pm
i was gonna say, break out some ceran wrap and protect that!
02 solara 2az
solara90
Postby kenny6683 » Mon Oct 05, 2009 6:47 am
this is better than nothing...check out this universal sunroof Item number: 160367113262
http://cgi.ebay.com/ebaymotors/POP-UP-U ... mainQ5f100
kenny6683
Postby LEE337 » Mon Oct 05, 2009 12:27 pm
kenny6683 wrote:this is better than nothing...check out this universal sunroof Item number: 160367113262
Wow! Thats not a bad alternative at all. I will definitley look into this one. The measurements seem to line up very nice.
Thanks Kenny! :D
Users browsing this forum: No registered users and 76 guests
