SolaraGuy.com • View topic - New TRD4Life Big Brake relocation brackets F/S
Postby ASG14 » Wed Sep 02, 2009 7:49 am
TRD4Life Big Brake relocation brackets, brand new.
$150 shipped
Have 2 in the picture, only 1 is for sale. The other went to Australia.
ASG14
Postby trd4life » Wed Sep 02, 2009 8:52 am
These brackets are greatly improved over older batches that were made ,these come with plug and play hardware :)!
Postby JMSinMaryland » Wed Sep 02, 2009 12:19 pm
I'm interested, what would be involved/parts for adding the Supra TT rotors/calipers (necessary? vs. using the Camry calipers), etc?
JMSinMaryland
Postby alltrac92 » Wed Sep 02, 2009 1:46 pm
Do you have to grind the brackets to fit the ES300 dual piston caliper?
alltrac92
Postby trd4life » Wed Sep 02, 2009 2:04 pm
Yes you do a little bit
Postby ASG14 » Wed Sep 02, 2009 3:47 pm
JMSinMaryland wrote:I'm interested, what would be involved/parts for adding the Supra TT rotors/calipers (necessary? vs. using the Camry calipers), etc?
Just the Supra rotor is all John. You can use your current calipers, OR use the bigger Gen 3 Cam/ES300 V6 calipers.
ASG14
Postby akora12 » Wed Sep 02, 2009 6:14 pm
+1 for this kit. I installed it this weekend, and the fit is great with the allen bolt option. I've had some of the other kits offered on here in the past, and I'd take this one over them.
Postby JMSinMaryland » Thu Sep 03, 2009 11:30 am
Let me find out how much the rotors would cost me and I'll let you know. Can we use both the standard Supra rotors and the twin turbo Supra rotors (or are they all the same?)
JMSinMaryland
Postby trd4life » Thu Sep 03, 2009 11:44 am
Twin turbo rotors only
Postby JMSinMaryland » Thu Sep 03, 2009 11:52 am
Will the Supra TT calipers fit as well?
JMSinMaryland
Postby akora12 » Thu Sep 03, 2009 11:59 am
^No.
Postby LEE337 » Thu Sep 03, 2009 1:46 pm
JMSinMaryland wrote:Will the Supra TT calipers fit as well?
Like akora12 said, no they wont fit.
...but you can use the twin piston calipers off a ES300 up front. :D
Thats what Im getting ready to do. 8)
My rotors are almost done.
Postby JMSinMaryland » Thu Sep 03, 2009 2:03 pm
PM sent, just ordered the TT rotors from the dealership for $150.
JMSinMaryland
Postby LEE337 » Thu Sep 03, 2009 2:06 pm
^You orderd the blanks??
Plan on getting them slotted and drilled???
Postby JMSinMaryland » Thu Sep 03, 2009 2:19 pm
Blanks, don't want to deal with the extra wear and tear from slotted/drilled/vented/cross-drilled/etc/etc.
I figure this is going to make a big enough difference (hopefully?) between stock and the upgrade.
JMSinMaryland
