SolaraGuy.com • View topic - FS: (2) 25 MM Spacers
Postby t3chnique » Mon Sep 21, 2009 9:09 am
I have 2 25MM Ichiba Version 2 spacers for sale with hubcentric rings.
Used for 2 weeks and then taken off because it was too aggressive.
12x1.5. For all Toyotas
Asking $110 local pickup or meetup in SoCal.
Will ship at buyers expense
t3chnique
Postby t3chnique » Wed Sep 23, 2009 5:59 pm
bump
t3chnique
Postby t3chnique » Fri Oct 09, 2009 9:31 pm
Bump
t3chnique
Postby Mr_Krispy1183 » Sat Oct 10, 2009 10:46 am
Bump for you bro. C'mon people, these compliment Sarki's SSRs also for sale here on the forum. Grab another set of 25mm (or even 35mm! for the rear) spacers, and you're good to go!
Postby funboy102 » Sat Oct 10, 2009 12:29 pm
Uhh, I'm new to spacers... How easy are these to install? What do I need to know about installing them? Might be interested to push our my rear wheels...
funboy102
Postby Mr_Krispy1183 » Sat Oct 10, 2009 3:41 pm
Hen-dog,
These type of spacers are SUPER easy to install. Jack up the car, remove wheel, slide on the spacer, bolt it on to the stock lugs, and reinstall wheel on the new extended lugs that are already pressed into the spacer. Reinstall lug nuts and you're done.
Postby funboy102 » Sun Oct 11, 2009 11:20 am
Thanks for the info Krisp! Does sound easy. So these are proven to be safe right? Like they have enough threads to bolt on lug nuts?
Another concern is rubbing. I have 18x7.5 rims with 225/40/18 tires lowered on Tein/Tokico. You think i'll rub?
funboy102
Postby indiglosolara » Sun Oct 11, 2009 11:54 am
whats your offsets on your wheels?
indiglosolara
Solara 2 xB
Solara 2 xB
Postby funboy102 » Mon Oct 12, 2009 1:07 am
I believe it is 40
funboy102
Postby KILLA CAM » Mon Oct 12, 2009 5:26 am
^If your offset is 40, adding 25mm spacers will change your offset to 15. So if you don't have your fenders pulled and rolled, I can almost guarantee you'll rub.
_________________________
Retired: Honda S2000
Current: E46 ZHP
KILLA CAM
Postby t3chnique » Mon Oct 12, 2009 4:48 pm
Bump
t3chnique
Postby t3chnique » Thu Oct 29, 2009 8:51 pm
Still available
t3chnique
Postby t3chnique » Sun Nov 01, 2009 10:55 am
Bump
t3chnique
Postby KILLA CAM » Sun Nov 01, 2009 11:34 pm
PMed
Current: E46 ZHP
KILLA CAM
Postby t3chnique » Thu Nov 05, 2009 5:40 pm
Still available
t3chnique
Users browsing this forum: Google [Bot] and 23 guests
