SolaraGuy.com • View topic - Toyota Solara window regulator & motor assembly Pass RH~
Postby abro319 » Mon Sep 21, 2009 10:46 pm
This unit was directly removed from my 00' Toyota Solara because the cord attached to the motor and regulator is out of sync. The motor still runs when passenger window button is pressed but for some reason, the cord connecting to the regulator does not register, therefore the passenger window does not work 60% of the time. The rest 40% of times it works just fine without problem. I have also noticed when the temperature rise above 95 degrees the window stops working. I purchased a new window regulator from the dealer for $325 bucks. I am selling mine for only $38 and shipping is $4
Passenger side window regulator & motor assembly Pass RH
Fits all 99 00 01 02 model Camry Solara coupes
Please contact me if you are interested. Pick up welcome.
Item sold as described (motor & regulator), no refund.
2000 Solara SLE V6 Diamond White Pearl
Lexus IS300 17" Rims
Former Eibach Springs, TRD RSB, Whiteline FSB, Tokico Strut User
abro319
