SolaraGuy.com • View topic - FS: Dats Y-pipe - *updated with pics* SOLD!
Postby Solarizona » Wed Sep 23, 2009 7:09 am
Hey guys,
Selling a used Dats y-pipe. I bought this from hskrsolara who had the flex section fixed, so it should bolt right up. After I bought this I remembered why I didn't get one before - I have cali spec headers :evil: So, anyone with federal spec headers this would be a great upgrade. This is just taking up space in my room, so hoping for fast sale - $150 shipped. If anyone needs pictures I can post some in a day or two. Thanks!
hskrsolara's sale post: http://www.solaraguy.com/viewtopic.php? ... highlight=
-Jonathan
Solarizona
Postby trd4life » Wed Sep 23, 2009 9:42 am
Why don;t you get some federal spec manifolds so you can use the pipe? I have a set.
Postby Solarizona » Wed Sep 23, 2009 12:24 pm
trd4life wrote:Why don;t you get some federal spec manifolds so you can use the pipe? I have a set.
Looks like I've got a small head gasket leak on the rear cylinder head, so I'm planning on getting the OBX setup installed when I have that repaired. BTW, anyone have any idea how much it should cost to replace the rear head gasket?
Solarizona
alot
Postby NRDriver » Wed Sep 23, 2009 5:56 pm
alot. lol. your lookin at 8.1 hours plus about 250 in parts and machining, etc.
at 80$ an hour thats 650$ in labor. since you are doing the headgasket you will probably be asked if you wanna do your water pump, timing belt, crank seal, cam seals, since your in there. also, you will be recommended to do both headgaskets since your in there.
i would say probably 1200 minimum. 2300 with everything done.
im just a mechanic and dont really do numbers but you should post up the quote you get and i can ask my service writer what he thinks
NRDriver
Postby hskrsolara » Thu Sep 24, 2009 12:13 am
damn, was hoping this would go to good use as it was an awesome mod on my 5.5psi solara. If you need oem federal spec headers, I have a set I would sell for pretty cheap. Let me know, maybe I can help you out.
hskrsolara
Postby 5842solara » Thu Sep 24, 2009 2:18 am
what is cali and federal spec headers?
would it fit on a stock exhaust mani?
5842solara
Re: alot
Postby Solarizona » Thu Sep 24, 2009 11:58 am
NRDriver wrote:alot. lol. your lookin at 8.1 hours plus about 250 in parts and machining, etc.
Thanks for the reply. $2300, ouch :-? That'd pretty much be a 5spd swap... I'll have to have my mechanic double check and show exactly where it's leaking.
Solarizona
Postby Solarizona » Thu Sep 24, 2009 12:01 pm
5842solara wrote:what is cali and federal spec headers?
California manifolds have pre-cats and federal don't. So, it'll fit stock manifolds if you have the federal setup.
Solarizona
Postby 5842solara » Thu Sep 24, 2009 8:30 pm
how you know which you have?
5842solara
Postby Solarizona » Mon Sep 28, 2009 8:55 pm
Pics posted and a bump.
Solarizona
Postby Dawgz » Mon Sep 28, 2009 9:04 pm
5842solara wrote:how you know which you have?
Take a pic of ur front header, and pm it to me. Ill tell u if its cali spec or not.
