SolaraGuy.com • View topic - TRD Supercharger + engine and 5 speed
Postby duneman11 » Mon Feb 22, 2010 11:54 am
I found this on ebay and thought i would share it with the rest of you
Its not mine
http://cgi.ebay.com/ebaymotors/Toyota-S ... 716wt_1167
duneman11
Postby GzNutz » Mon Feb 22, 2010 11:57 am
Will be intersting to see what this goes for.
Postby duneman11 » Mon Feb 22, 2010 11:57 am
wish i would have found this before i bought my parts for my v6 swap into my camry. but my lose is you gain.
duneman11
Postby TxBmbleBee » Mon Feb 22, 2010 8:40 pm
i can see gabe buying that...or greg picking it up, it is in cali?
"i just wanna go fast..."
TxBmbleBee
Postby duneman11 » Mon Feb 22, 2010 8:45 pm
it says the buyers location is in cali
duneman11
Postby michaelr295 » Tue Feb 23, 2010 3:32 pm
screw i want that motor
red 99 solara v6 non sc/at custom intake custom ehxaust jdm flat black rims lol
trans cooler b&m trickshift in trans safc more to come (frist dyno 151hp/178tq) safc tune (157whp&178 tq)
posting dyno graph soon
michaelr295
Postby 02slera » Tue Feb 23, 2010 6:51 pm
i want that blower.
what a good price.
damn.
2002 Solara SLE v6
02slera
Postby Twin Turbo » Tue Feb 23, 2010 6:56 pm
How much does a 1MZ weigh?
Follow @ballsofthunder for non-stop ridiculous action
Twin Turbo
Postby 02slera » Wed Feb 24, 2010 7:47 pm
^^ damn i cant find it, i have read though that the 1mzfe is comparable or close in weight to some 4 cylinder engines that are iron because the v6 is aluminum block and heads (i think the heads may have iron in part of them)
"The Toyota MZ engine family is a V6 piston engine series. The MZ series has an aluminium engine block and aluminium alloy DOHC cylinder heads. The cylinders are lined with cast iron, and is of a closed deck design (no open space between the bores). It uses multiport fuel injection (MFI), four valves per cylinder, a one-piece cast camshaft and a cast aluminium intake manifold. The MZ family is a lightweight V6 engine of an all-aluminium design, using lighter weight parts than the heavier duty VZ block engines in an effort to lower production costs, decrease engine weight, and decrease reciprocating weight without sacrificing reliability. Toyota sought to enhance the drivability pattern of the engine (over the 3VZ) at exactly 3000 rpm, since that was the typical engine speed for motors cruising on the highway. The result was less cylinder distortion coupled with the decreased weight of rotating assemblies, smoother operation at that engine speed, and increased engine efficiency.
They feature cast aluminium pistons with an anti-friction resin coating (moly) and valve depressions on motors without VVT-i. They also use steel rings, smaller-diameter shot-peened rods, and a forged steel crankshaft."
2002 Solara SLE v6
02slera
Postby 99BlackSandv6 » Sun Feb 28, 2010 7:16 pm
It sold. $1825
All 7 bids made in the last 10 minutes.
Postby alltrac92 » Sun Feb 28, 2010 7:20 pm
I wonder if anyone from here got it. The charger needs a new actuator and who knows if it came with the egr pipe.
alltrac92
Postby 99BlackSandv6 » Sun Feb 28, 2010 8:07 pm
No, in the pics you can see the actuator is hanging there and the egr pipe is there as well.
I think that the actuator is just partially disassembled.
Postby SpeedySolara » Sun Feb 28, 2010 9:15 pm
where would you even get an actuator? without it the blower is useless. i noticed that was missing too but 99BlackSandv6 is right, the egr tube is there.
SpeedySolara
Postby ToyoSolV6 » Sun Feb 28, 2010 11:27 pm
hmm i wonder if this dude i know bought it lol
if this is the same one he was getting i think the only thing wrong with it was the by pass
Postby trd4life » Mon Mar 01, 2010 5:25 am
does wasnt worth the money if the motor was sludged and the charger needed a rebuild.
Users browsing this forum: Google [Bot] and 23 guests
