SolaraGuy.com • View topic - FS: Gen 3/4 Camry Big Brake Setup Front/Rear
Postby SlammedSix » Mon Mar 29, 2010 1:28 am
I have a set of Big brake kit brackets for the Gen 3/4 Camry. They are to allow you to run a 13" rotor from a Toyota Supra and your OEM Camry brake caliper. I will include all bolts and nuts and both front brackets.
**$140 Shipped**
I also have BRAND NEW UNUSED Toyota Supra TT Front Rotors to match the brackets for a complete bolt on.
**SOLD**
I also have BRAND NEW UNUSED Camry Wagon/ES300 Rear rotors They are bigger than normal camry rotors and you can use them with your OEM caliper just need the Wagon/ES300 brake caliper bracket. These with the Supra Front rotors will make the ultimate brake setup all the way around.
**$100 Shipped**
SlammedSix
Postby SlammedSix » Sun Apr 04, 2010 10:01 pm
Open to offers......I've lost my job and really need to get rid of these parts
SlammedSix
Postby Slut » Tue Apr 06, 2010 9:17 pm
Can they fit with the stock 16" wheels? If so im interested in both.
Slut
Postby SlammedSix » Tue Apr 06, 2010 11:29 pm
The front rotors are sold. I still have the front brake caliper brackets, and the rear rotors. The rear rotors will fit under your stock 16" wheels, but when installing the front setup it will require at least a 17" rim
SlammedSix
Re: FS: Gen 3/4 Camry Big Brake Setup Front/Rear
Postby SlammedSix » Tue Oct 12, 2010 12:40 am
Will accept any reasonable offer.
Toss one out
SlammedSix
NEW PARTS
Postby SlammedSix » Tue Oct 12, 2010 4:05 pm
I have a set of Camry Wagon rear brake caliper brackets that are needed for the use of the rotors I have listed as well. Your gen 3 caliper will bolt right up on these brackets and makes it a complete bolt on application. If you have a Solara you will need a Gen 3 Camry rear brake caliper as well to complete this setup, as the Gen 3 caliper is larger than the Solara Gen 1.
**$40 Shipped**
**I will sell the rear rotors and caliper brackets for $120 Shipped as a package deal**
Toss one out
SlammedSix
