SolaraGuy.com • View topic - FS: MSD DIS-4 Ignition System For Boosted Camry/Solara V6
Postby trd4life » Fri Apr 16, 2010 6:22 am
I have for sale a mint condition MSD DIS-4 High Output ignition box , with the two needed MSD tach adapters to use on the 97-01 Camry V6, and 99-03 Solara. The box has a two step rev limiter built in for you 5 speed drag racing guys! The box alone retails for $625+, plus another $70 a pop for the tach adapters.
Be ahead of the rest of the competition with this box. GregTRD can supply you a Camry/Solara specific instruction manual.
I'll take $400 SHIPPED, because i could use the cash ( i wanted to save this for a project)
More info here.
http://www.msdignition.com/Products/Spo ... utput.aspx
thanks guys
Gabe
trd
Postby albertrd » Sat Apr 17, 2010 1:05 am
someone should jump on this, gregtrd has one on his camry, this a great upgrade for anyone thats boosted, hey gabe my brother said that he'll send the buyer step by step instructions on how to install this msd for the camry/solara.
albertrd
Postby SpeedySolara » Sat Apr 17, 2010 3:14 am
Do you know if this will set off any CEL's, especially being its not CARB approved?
SpeedySolara
carb
Postby Gregtrd » Sat Apr 17, 2010 8:08 am
Its carb approve I got the carb sticker and it won't set any cel.
SpeedySolara wrote:Do you know if this will set off any CEL's, especially being its not CARB approved?
The Fastest Camry in Socal
366whp / 427wtq @10.5psi
Gregtrd
Postby TxBmbleBee » Sat Apr 17, 2010 10:24 am
what does it do?
"i just wanna go fast..."
TxBmbleBee
Postby trd4life » Sat Apr 17, 2010 10:34 am
* Two adjustable Rev Limits
* Diagnostic LED
* Adjustable retard stage
* Ignition Interrupt Circuit
The DIS Ignitions all deliver a stout, CD spark that is capable of burning the majority of air/fuel mixtures. There are of course exceptions, such as full bred race engines running high boost pressures from turbos, blowers or nitrous. To answer these needs, we offer a Higher Output version of the DIS Ignition Controls.The DIS Plus HO Ignitions produce an incredible 170 millijoules of spark energy with 470 primary volts. This increased output will light up fuel mix­tures even under extreme cylinder pressures.The DIS-HO boxes are not CARB approved and are designed for drag racing applications only.
Postby trd4life » Sun Apr 18, 2010 10:33 am
bump need this gone!
Postby trd4life » Tue Apr 20, 2010 8:28 pm
BUMP!
Postby ToyoSolV6 » Tue Apr 20, 2010 9:01 pm
2 STEP!!!
sick i want it..
Gabe if you still have it in a couple of weeks ill take it.
ill hit u up
Postby trd4life » Wed Apr 21, 2010 10:27 am
bump bump bump bump bump
Postby SirThomas88 » Thu Apr 22, 2010 2:09 pm
SirThomas88
Postby trd4life » Thu Apr 22, 2010 7:22 pm
SOLD!!!!!!!!!!!!!!
