SolaraGuy.com • View topic - FS: 5SFE Turbo Kit
FS: 5SFE Turbo Kit
FS: 5SFE Turbo Kit
Postby trd4life » Tue May 04, 2010 11:40 am
I have for sale 98% of the parts you need to turbo your Solara/Camry 5SFE the right way . I do not know all the specific details on the turbo itself, i do know its a real Garett T3 and is in good working order. Not sure if its Ball bearing or not, if you would like the part # to do more research i would be happy to give you any markings or numbers that are on the turbo.
You will need a blowoff valve welded onto a 2" diameter 5" long section of pipe, turbo and wastegate gaskets, and misc nuts and bolts to complete the the kit. you'll need to tap your oil pan. You will need misc, rubber hoses for coolant feed lines. I Would also suggest an apexi safc, a manual boost controller to go along with the kit.
Comes with a 2.5" downpipe with external wastegate pipe dumped back into downpipe. This is the rare piece of this kit!! A shop would charge big bucks for this downpipe setup.
Heres whats included.
1) Real Garrett T3 oil and water cooled turbo.
2) Real Toyomoto Turbo Exhaust Manifold
3) Custom made 2.5'' downpipe
4) Real Turbonetics External Wastegate (8psi wastegate spring)
5) Custom Sidemount intercooler with piping , couplers, and clamps (missing BOV and small section of straight 2" pipe)
6) T adapter for OEM oil pressure sensor and turbo oil feed line
7) Supra 315cc Lime green 7MGE Fuel injectors (plug and play)
8) Walbro 190lph fuel pump
9) MR2 Turbo MAP sensor
10) RARE 60mm Greddy white face Electric Boost gauge with sending unit and pressure sensor.
11) Custom 3" intake pipe with new Spectre filter
12) New Summit Racing Battery Relocation Kit
13) Jackson Racing 5:1 Rising Rate Fuel pressure regulator
I hope to find someone here on the forums that will appreciate this kit and put it to good use.
I do not wish to part out a this point unless i find buyers for all the items individually.
$1200 obo. More than fair for all the extra crap i am throwing in.
Please please no lowballers. I will consider reasonable offers only. Anyone that knows anything would understand this downpipe cost a lot to have made.
Thanks
Gabe
Postby NXRACER » Tue May 04, 2010 5:33 pm
wow.... too bad i dont have $1200 & live in socal. but i never thought about the batt relocation kit, that mod can help me sqeeze in an oil & coolant catch can easier (searching for tutorial now)
-'92 Camry Base, MT, 5S-FE--- mostly stock sofar
NXRACER
Postby hskrsolara » Tue May 04, 2010 5:35 pm
what kind of power was this putting down?
hskrsolara
Postby trd4life » Wed May 05, 2010 7:00 am
160whp and 185 tq running lean at 8psi. This Setup needed more fuel until i added the jackson racing 5:1 FMU, never dynoed after FPR install but it should be higher now.
thanks
gabe
Postby solara90 » Wed May 05, 2010 2:58 pm
i bet you could get some more ponies easily by switching to a front mount intercooler too
02 solara 2az
solara90
Postby Sasebo » Wed May 05, 2010 4:12 pm
This would be cool for my 5sfe. Unfortunately its just too much for me atm. Too bad.
Sasebo
Postby trd4life » Thu May 06, 2010 4:34 am
yup a front mount would add more power as well.
Postby GreeKAvaLoN » Thu May 06, 2010 10:38 pm
if only i could convince my friends mom to sell me her 38kmi gen3.. i want a turbo so badd. was this on that one silver gen3?
GreeKAvaLoN
Postby trd4life » Fri May 07, 2010 3:09 pm
one of you 5sfe solara guys take the plunge i'll give you a sick deal on this kit it performs really well.
