SolaraGuy.com • View topic - FS: OEM used ECM, VSV for EGR, ECT for EFI and AFR O2
Postby feniks » Sat Jul 10, 2010 6:15 pm
Recently I have been pursuing high positive fuel trims at warm idle on my car (2000 Camry Solara SE 2.2L 5S-FE) and decided to replace a few sensors and the VSV. it all changed literally nothing per my problem (reason turned out to be purely electrical) and those below sensors are perfectly fine and might serve you for a very long time (e.g. VSV for EGR and ECT for EFI rarely go bad).
Sensors are in same condition as i pulled them out, they were never cleaned with anything (didn't even wiped them clean) as i was afraid to damage something. They look exactly same as after removing them from car.
To make this clear: I NEVER HAD ANY TROUBLE CODES RELATED TO ANY PARTS I SELL HERE. I was replacing them with brand new parts while tracking down my fuel trims problem (still happening with all below new).
Pictures are REAL and were NOT touched or photoshopped. If you need more or better pics at different angles, let me know.
Bottom line is that all those sensors (and VSV) work perfectly fine and are for sale.
Items are located in Wallington, NJ 07057. Take them if you want. Selling as is. PM me if interested.
I.
Engine Coolant Temperature:
Description: ECT for EFI
OEM part number: 89422-35010
Pictures:
http://img714.imageshack.us/img714/3157/p1010003w.jpg
http://img3.imageshack.us/img3/2728/p1010005lm.jpg
Age: 72,551 miles
Notes:
New OEM/Denso sensor I installed in its place didn't change ANYTHING, so this sensor must have been working fine, showing same temps via obd2 as good as brand new one.
Price:
Price of brand new one from [url="http://www.trademotion.com/partlocator/index.cfm?siteid=215498"]online Toyota dealer[/url] is $47.58 +s/h
[COLOR="Red"]I'm asking only $25.00 (shipping free)[/COLOR]
Warranty: As is.
II.
Exhaust Gas Recirculation:
Description: VSV for EGR (on the back of engine block, below intake manifold)
OEM part number: 25860-74050
Pictures:
http://img706.imageshack.us/img706/3383/p1010007zrx.jpg
Age: 73,700 miles
Notes:
New OEM/Denso VSV I installed in its place didn't change ANYTHING per my problems with EGR, so it must have been working fine.
As you can see the VSV itself is perfectly fine and very clean (i was surprised), only the metal bracket is covered with a little rust, but this is nothing per functionality. Both ports and filter look clean like new.
I have tested this VSV per FSM (gen4 SFI, page 43) and it passed all tests with flying colors every time. It's same good as brand new one.
Price:
Price of brand new one from [url="http://www.trademotion.com/partlocator/index.cfm?siteid=215498"]online Toyota dealer[/url] is $58.89 + s/h
[COLOR="Red"]I'm asking only $30.00 (shipping free)[/COLOR]
Warranty: As is.
III.
Oxygen sensors:
a)
Description: upstream Air/Fuel ratio sensor (california specs only)
OEM part number: 89467-33020
Pictures:
http://img42.imageshack.us/img42/8351/p1010012na.jpg
http://img27.imageshack.us/img27/187/p1010013xk.jpg
Age: 71,700 miles
Notes:
It still includes original electrical connector intact.
New NTK sensor I installed in its place didn't change ANYTHING, so this sensor must have been working fine. It might be only a little slower than brand new sensor, but for this price you can get it and either live with it for another 70k miles or re-use the electrical connector for splicing, replacement, etc.
Price:
Price of brand new one from [url="http://www.trademotion.com/partlocator/index.cfm?siteid=215498"]online Toyota dealer[/url] is $176.65 + s/h
[COLOR="Red"]I'm asking only $50.00 (shipping free)[/COLOR]
Warranty: As is.
b)
Description: downstream narrow band o2 sensor (for federal and california specs same)
OEM part number: 89465-06040
Pictures:
http://img229.imageshack.us/img229/723/p1010009d.jpg
http://img257.imageshack.us/img257/7535/p1010010o.jpg
http://img526.imageshack.us/img526/5667/p1010011o.jpg
Age: 71,400 miles
Notes:
As you can see i have stripped it a little bit (shouldn't be any problem during installation though). This one was a bitch to remove due to tight working space under car. eventually i got it off using my 1/2'' click-stop torque wrench (breaker bar was too big to fit in).
It still includes original electrical connector intact as well as grommet and wire clip that fits under car.
Price:
Price of brand new one from [url="http://www.trademotion.com/partlocator/index.cfm?siteid=215498"]online Toyota dealer[/url] is $111.03 + s/h
Warranty: As is.
IV.
ECM / ECU Engine Control Module/Unit:
Description
: Original factory (built APR 2000) ECM from '00 Solara SE 2.2L (calif specs, no immobilizer, automatic).
OEM part number: 89666-06041
Pictures:
http://img231.imageshack.us/img231/5743/p1010008sl.jpg
http://img59.imageshack.us/img59/2285/p1010009ts.jpg
Age: 74,600 miles
Notes:
It is said that same exact components (including the ECM, engine, transmission and everything under hood) was also used for respective 2000-2001 Camry gen4.5 models (also calif specs, no immobilizer, automatic).
There is nothing wrong with computer. The sole reason why i replaced it, was because i cannot find the source of my fuel trims problems and decided to replace it with the one with latest software revision (from junk yard). It works perfectly fine and is VERY clean (unlike those junk yard pulls), perfect condition.
Newer software revision ECM I got from junk yard (89666-06121) didn't change ANYTHING, so this old computer must have been working fine, no errors, no problem. I replaced it only because i wanted a newer software revision on the computer and was hoping it would solve my trouble (it didn't).
Price:
Price of brand new one from [url="http://www.trademotion.com/partlocator/index.cfm?siteid=215498"]online Toyota dealer[/url] is $1,010.90 +s/h (for new 89666-06121)
[COLOR="Red"]I'm asking $95.00 (shipping free)[/COLOR] because it looks pretty :)
Warranty: As is.
Above items are not intended for tune up. I am trying to sell them to people who get annoying error codes and are looking for a cheap & quick repair or want them to re-use e.g. electrical connectors.
Drop me a PM if interested in any of those items or need more info. Free USPS Shipping within continental US.
Thanks for looking!
ANY comments appreciated :)
Somehow this forums doesn't resize BBCODE embedded pictures and it cuts them, so PLEASE CLICK THE LINK ABOVE PIC to see the whole image!
'02 Solara SLE 1MZ-FE/A541E Coupe .: Denso : Akebono SP : HIR :. @ 125k
'00 Solara SE 5S-FE/A140E Coupe .: NGK : Hawk HPS : Philips Xtreme : RC : Magnefine :. @ 79k
feniks
