SolaraGuy.com • View topic - Polyurethane Mounts for 1MZ-FE and 5S-FE
Postby Eye8Pussies » Mon Jul 26, 2010 2:29 pm
I have 3 mounts for sale that were made a while back, and that's all that I have, so please don't ask if I have anything else. These were left over from people asking me to help them make the mounts, but they were unfortunately unable to pay for them, so I am recouping my costs.
All the mounts were done in yellow polyurethane at a 75 duromometer called dead bounce that absorbs more vibrations than conventional polyurethane- great for both street and track use, and for both boosted and non-boosted applications as well as automatic and manual.
I have for sale, 1x 5S-FE rear mount- on the 5sfe design, this mount is as important as the front mount in preventing the motor from rocking back and forth on acceleration. Due to the amount of torque that is available on the 5sfe, the stock oem units tend to disintegrate pretty quickly. This rear mount was pulled from an automatic 5s-fe, and it might fit the 5-speed, but you will have to look into part numbers to be sure.
And I have for sale, 2x 1MZ-FE front mounts. These are units from the gen3 1mz's which are more solid than the gen4 ones due to their size. They will bolt on to both the gen3 and gen4 1mzs though. The white seen in the pictures is just polyurethane caulking used to seal the weld points (the mount is cut in half and sand-blasted to ensure proper adhesiveness of the polyurethane on the inside of the mount) and prevent them from rusting. The entire mount will also need to be painted after it has been received to prevent rust, as the sand blasting and heat process used to remove the old rubber damages the original paint.
The price for all 3 mounts is the same- 200 each shipped within Canada or the US
I can be contacted through PM or e-mail: eye8pussies AT hotmail.com
Re: Polyurethane Mounts for 1MZ-FE and 5S-FE
Postby SleeperSolara » Mon Jul 26, 2010 8:21 pm
Can you seperate??
I want to see if i can take a 1MZ mount from you......
Postby Eye8Pussies » Mon Jul 26, 2010 8:34 pm
whoops....sorry, just realized that I wasn't so clear about the price- they're 200 each shipped
so yeah....I wasn't intending on selling all 3 as a set since nobody would have use for all 3 lol
pm me if interested
