SolaraGuy.com • View topic - AKORA12's MASSIVE PART OUT
Postby akora12 » Wed Sep 01, 2010 12:33 pm
I'm sad to say my solara is done. My tranny gernaded last week and I have no more energy to keep the project going. I plan to spend my time working on a boat that I just purchased, so I’m afraid I won’t be tuning cars for a while. If anyone is interested in the car itself, PM me for my phone number. I will be returning the car to stock including the motor.
I’ve priced everything to sell, so I won’t be entertaining any offers at this time. Unless otherwise noted, all parts are still on the car. I’ll remove them as they sell within a two-days time max, if possible. I’ll also add pics as soon as I can. I won’t be holding any of these parts, so the first to pay gets them. My paypal is akora12@yahoo.com.
As things are purchased, I will delete the listing for that part entirely. As I'm doing most of this from my phone, the thread should be updated 24/7.
Also, please add 2.9% for PayPal fees.
3.1 1MZ-FE
Recently rebuilt with all new parts including pumps, bolts, etc. Crankshaft was balanced and micropolished, and the cylinders were rebored to accommodate new piston rings from Arias. Block and valve covers were powder coated satin black. Includes everything except water inlet housing and intake manifold. There was a slight ticking in the heads above the number two cylinder, but it should be a simple shim change. Compression test shown all cylinders within a 3% variance. Motor has only been run for less than 3k miles, but is fully broken in. Please call me for more details. $4.5k + freight.
TRD 1MZ-FE Supercharger
This supercharger is in perfect condition with only 12k miles of use since I had it rebuilt. The rebuild was done by a professional Eaton service shop and included all new bearings, seals and coupler. The idler pulleys were also serviced and greased at that time. Unit includes ALL factory parts including manual EGR tube and installation instructions. I will also include a bottle of synthetic nose-assembly oil that was provided by the rebuild shop and was used to fill the unit at the time of rebuild. This has to be the lowest-mileage gen. 1 unit on the market today. $2,700 shipped.
Pulley Boys 6 psi Supercharger Pulley—Black
Used, but in excellent cosmetic and functional condition. $50 shipped.
Pulley Boys 9 psi Supercharger Pulley—Black
Brand new. $65 shipped. Part off car.
TRD Alternator Bolt
Brand new authentic TRD piece. Very rare! $30 shipped. Part off car.
Jim’s Fuel Mod
Used for 13k miles. Features custom-ordered black hoses. $65 shipped.
Jim’s Fuel Lines/Fittings
Brand new -6AN lines custom made by Jim to match my black fuel mod kit. Includes a 24" hose and 16" hose with female fittings. I will also include two -6AN to 12x1.25mm fuel rail fittings. $45 shipped. Part off car.
Jim’s Torque Rod
Includes black insulators on unit and for lower mount to prevent noise. $40 shipped.
XERD Headers
Only set of long-tube headers ever made available for the 1MZ-FE. These were recently welded to seam up two small holes the previous owner had. $800 shipped.
TRD Muffler
Bought new and used for 3k miles. Includes original hardware, box and paperwork. $200 shipped.
URD O2 Simulator
$40 shipped. Part off car.
Injen Intake
Stainless finish with no decal. Has 1/8" NPT port welded for the meth injection nozzle, but I will include a plug if you want to use it without the fitting. Includes original box, hoses, couplers, filter and license plate frame. $100 shipped.
Snow Stage 2 MAF Meth/Water Injection Kit
Includes all hardware, instructions and tank. $275 shipped.
Lexus ISx30 Wheels/Falken Tires/Lugs
Set of all front 18x8 wheels custom powder coated in anthracite metallic and coated with a ceramic clear. Includes Toyota center caps and lugs. Comes mounted with Faken FK-452 tires in 225/45 size. Used for only 7.5k miles and rotated at 6k miles. $1,200. Please inquire about shipping.
OEM Wheel Locks
Factory Toyota locks with key. $40 shipped.
Ksport Coilovers
Only used for 8k miles. Never saw snow or ice. Includes original box, hardware, instructions, etc. $750 shipped
Walbro 190 Fuel Pump
Used for 13k miles. Includes original hardware and necessary parts for a plug-n-play installation, including OEM fuel sock. $60 shipped.
2JZ-GE Supra Blue-Top Injectors
Recently cleaned and flow tested by WitchHunter Performance less than 100 miles ago. I will include test sheet to verify. $150 shipped.
Aeromotive FP Regulator
Brand new dual-inlet unit for use with -6AN o-ring fittings. I will include two new Earls -6AN 90-degree swivel fittings and a new Aeromotive 1/4" hose-barb fitting for the return. $160 shipped. I will include the 1/16"-1/8" adapter and boost line t-fitting for an additional $10. Part off car.
VDO Fuel Pressure Gauge
Brand new. Features a black face with red needle. 0-100 psi reading. Will work great on the Aeromotive FPR or as a stand-alone piece within the fuel mod. $30 shipped.
TRD Boost Gauge
Bought new and used for 13k miles. Features black face. I will include green bulb-covers to match to OEM cluster and original box and instructions. $80 shipped.
VDO Oil Pressure Gauge
Closest match to TRD gauge I've found. Black face with red pointer. Includes sender and green bulb covers to match OEM cluster. 0-100 psi reading. $30 shipped.
Greddy Oil Adapter
Bought new and used for less than 3k miles. Bolts to oil filter fitting and accepts many ports for oil pressure/temp. gauge. $45 shipped.
Kaminari Lip Kit
Full kit with no cosmetic defects. Painted silverstream opalescent by professional body shop. Paint cost over $1k alone. Includes 3M prep wipes and installation instructions. $700 shipped.
Supra Brake Brackets
Gabe's custom kit with correct bolts that do not need modified. $100 shipped.
Centric Supra Rotors
Used for 3k miles. Has black-coated hubs, vanes and area caliper doesn't clear so NO rust will be present on areas not touched by pad. RH rotor has a very minor surface scrape from one of the pad clips, but should work out with use. $75 shipped.
ES300 F + R Calipers
Freshly rebuilt OEM units with 3k miles of use. Coated with satin black paint and properly baked for longevity. Front calipers are dual piston. $220 shipped.
Poly Engine/Tranny Mounts
Complete set of mounts, including front and rear motor mounts as well as tranny mount. $500 shipped.
EGR Block-Off Plates
Set of four custom-made aluminum plates. $30 shipped.
OEM Knock Sensor + Mount
Factory Toyota sensor with custom-built mount to relocate near water outlet neck. Includes bolt and modified OEM wiring harness. This was hands down better than any other knock sensor relocation out there. $65 shipped.
OEM LH Axle Hub
Bought as a replacement from a vehicle with 72k miles. Includes ABS sensor. $65 shipped. Part off car.
OEM Engine Cover
Professionally painted by a body shop at the time I had my kit painted. It has 3 coats of silverstream opalescent and 2 of clear. Used for less than 1k miles. $100 shipped. Part off car.
OEM Dog Bone + Super Pro Poly Bushings
Only used for 6k miles. Comes ready to install so you don't have to mess with getting the bushings pressed in by a shop. $75 shipped. Part off car.
TRD Smooth Idler Pulley
Brand new. Authentic toyota replacement part. $25 shipped. Part off car.
OEM Gen. 4 Camry Return-Fuel Rails
Bolt-return rails to make an easy return-fuel system. $45 shipped. Part off car.
OEM Lexus 3VZ-FE Return-Fuel Rails
Anodized aluminum and drilled/tapped for 12x1.25 fittings on all four sides. These didn't line up perfectly on my intake manifold. $35 shipped. Part off car.
Re: AKORA12's MASSIVE PART OUT
Postby CASTRO » Wed Sep 01, 2010 12:55 pm
Was wondering if you would be willing to ship the poly dog bone engine mount?
CASTRO
Postby 99BlackSandv6 » Wed Sep 01, 2010 1:50 pm
I've got my on a couple things, but I probably shouldn't.
It sucks to see you parting out.
GLWS!!!
Postby trd4life » Wed Sep 01, 2010 2:01 pm
dibs on oil cap, trd strut bar, safc2, pillar pod
Postby DSM_Lara » Wed Sep 01, 2010 2:04 pm
trd4life wrote:dibs on oil cap, trd strut bar, safc2
ahhh come on Gabe I wanted the Strut bar. :cry: :puppydogeyes: :puppydogeyes: :puppydogeyes: :puppydogeyes: :puppydogeyes:
TRD Strut Bar
Bought new and used for 13k miles. Has notch for the boost fitting. Has a few surface scratches, but is otherwise in very good condition. $75 shipped.
TRD Boost Gauge
Autometer Dual Gauge Pod
Extremely rare! This was the authentic pod made to fit the gen. 1/1.5 solara. Has LED in each pod for meth on and low level, but could be used for anything. $40 shipped.
Interested on these.....^^^^
DSM_Lara
Postby yaddadaimsayin » Wed Sep 01, 2010 2:06 pm
damn thats a massive partout
Postby trd4life » Wed Sep 01, 2010 2:10 pm
sorry guys i have been hunting for the pod and bar for several months
Postby DSM_Lara » Wed Sep 01, 2010 2:10 pm
trd4life wrote:sorry guys i have been hunting for the pod and bar for several months
Me Too.... wait what pod? safc? blah you edit lol...
DSM_Lara
Postby GreeKAvaLoN » Wed Sep 01, 2010 2:12 pm
akora, can you give me a call when you're free? i'll pm you my number..
GreeKAvaLoN
Postby mig0s » Wed Sep 01, 2010 2:33 pm
Wow why you guys have to dib on everything don't you all have enough??? >.<
mig0s
Postby monksta408 » Wed Sep 01, 2010 2:40 pm
dibs on UPFD CAI Extension! :D
99 Lara SLE A/T 3.0L V6
monksta408
Postby DSM_Lara » Wed Sep 01, 2010 2:47 pm
I'll back out on all those guages if Gabe takes A-Pillar Pod. :(
DSM_Lara
Postby SirThomas88 » Wed Sep 01, 2010 2:52 pm
Dibs on the Aeromotive FP Regulator! I'll take it. Getting return-style fuel rails installed soon.
I might be interested in the Oil Pressure Gauge as well. So if DSM_Lara doesn't take it I'll be second in line.
SirThomas88
Postby akora12 » Wed Sep 01, 2010 4:45 pm
Just to confrim, I won't be holding dibs on any of these parts. The first to pay is the first to get the part. Gabe is the only exception to that considering the help he's provided me in acquiring many of these parts. Also, I have several other parts that I still have to list for sale, so keep posted. Thanks!
Ryan
Postby ToyoSolV6 » Wed Sep 01, 2010 4:46 pm
Just PM'ed you
