SolaraGuy.com • View topic - AKORA12's MASSIVE PARTOUT3
Postby akora12 » Sun Sep 26, 2010 2:17 pm
akora12 wrote:This is an updated post to my two previous ones that are currently locked. The new site won't let me update the thread after so many days, so I had to continue here in order to keep the original post updated.
I'm sad to say my solara is done. My tranny gernaded last week and I have no more energy to keep the project going. I plan to spend my time working on a boat that I just purchased, so I’m afraid I won’t be tuning cars for a while. If anyone is interested in the car itself, PM me for my phone number. I will be returning the car to stock including the motor.
I’ve priced everything to sell, so I won’t be entertaining any offers at this time. Unless otherwise noted, all parts are still on the car. I’ll remove them as they sell within a two-days time max, if possible. I’ll also add pics as soon as I can. I won’t be holding any of these parts, so the first to pay gets them. My paypal is akora12@yahoo.com.
As things are purchased, I will delete the listing for that part entirely. As I'm doing most of this from my phone, the thread should be updated 24/7.
Also, please add 2.9% for PayPal fees.
3.1 1MZ-FE
Recently rebuilt with all new parts including pumps, bolts, etc. Crankshaft was balanced and micropolished, and the cylinders were rebored to accommodate new piston rings from Arias. Block and valve covers were powder coated satin black. Includes everything except water inlet housing and intake manifold. There was a slight ticking in the heads above the number two cylinder, but it should be a simple shim change. Compression test shown all cylinders within a 3% variance. Motor has only been run for less than 3k miles, but is fully broken in. Please call me for more details. $4.5k + freight.
TRD 1MZ-FE Supercharger
This supercharger is in perfect condition with only 12k miles of use since I had it rebuilt. The rebuild was done by a professional Eaton service shop and included all new bearings, seals and coupler. The idler pulleys were also serviced and greased at that time. Unit includes ALL factory parts including manual EGR tube and installation instructions. I will also include a bottle of synthetic nose-assembly oil that was provided by the rebuild shop and was used to fill the unit at the time of rebuild. This has to be the lowest-mileage gen. 1 unit on the market today. $2,700 shipped. Part off car.
Pulley Boys 9 psi Supercharger Pulley—Black
Brand new. $65 shipped. Part off car.
TRD Alternator Bolt
Brand new authentic TRD piece. Very rare! $30 shipped. Part off car.
Jim’s Fuel Mod
Used for 13k miles. Features custom-ordered black hoses. $65 shipped.
Jim’s Fuel Lines/Fittings
Brand new -6AN lines custom made by Jim to match my black fuel mod kit. Includes a 24" hose and 16" hose with female fittings. I will also include two -6AN to 12x1.25mm fuel rail fittings. $45 shipped. Part off car.
Jim’s Torque Rod
Includes black insulators on unit and for lower mount to prevent noise. $40 shipped.
XERD Headers
Only set of long-tube headers ever made available for the 1MZ-FE. These were recently welded to seam up two small holes the previous owner had. $800 shipped
Injen Intake
Stainless finish with no decal. Has 1/8" NPT port welded for the meth injection nozzle, but I will include a plug if you want to use it without the fitting. Includes original box, hoses, couplers, filter and license plate frame. $100 shipped. Part off car.
Lexus ISx30 Wheels/Falken Tires/Lugs
Set of all front 18x8 wheels custom powder coated in anthracite metallic and coated with a ceramic clear. Includes Toyota center caps and lugs. Comes mounted with Faken FK-452 tires in 225/45 size. Used for only 7.5k miles and rotated at 6k miles. $1,200. Please inquire about shipping.
OEM Wheel Locks
Factory Toyota locks with key. $40 shipped.
2JZ-GE Supra Blue-Top Injectors
Recently cleaned and flow tested by WitchHunter Performance less than 100 miles ago. I will include test sheet to verify. $150 shipped.
VDO Fuel Pressure Gauge
Brand new. Features a black face with red needle. 0-100 psi reading. Will work great on the Aeromotive FPR or as a stand-alone piece within the fuel mod. $30 shipped. Part off car.
TRD Boost Gauge
Bought new and used for 13k miles. Features black face. I will include green bulb-covers to match to OEM cluster and original box and instructions. $80 shipped.
VDO Oil Pressure Gauge
Closest match to TRD gauge I've found. Black face with red pointer. Includes sender and green bulb covers to match OEM cluster. 0-100 psi reading. $30 shipped.
Greddy Oil Adapter
Bought new and used for less than 3k miles. Bolts to oil filter fitting and accepts many ports for oil pressure/temp. gauge. $45 shipped.
Centric Supra Rotors
Used for 3k miles. Has black-coated hubs, vanes and area caliper doesn't clear so NO rust will be present on areas not touched by pad. RH rotor has a very minor surface scrape from one of the pad clips, but should work out with use. $75 shipped.
ES300 F + R Calipers
Freshly rebuilt OEM units with 3k miles of use. Coated with satin black paint and properly baked for longevity. Front calipers are dual piston. $220 shipped.
Poly Engine/Tranny Mounts
Complete set of mounts, including front and rear motor mounts as well as tranny mount. $500 shipped.
OEM LH Axle Hub
Bought as a replacement from a vehicle with 72k miles. Includes ABS sensor. $65 shipped. Part off car.
OEM Engine Cover
Professionally painted by a body shop at the time I had my kit painted. It has 3 coats of silverstream opalescent and 2 of clear. Used for less than 1k miles. $100 shipped. Part off car.
OEM Gen. 4 Camry Return-Fuel Rails
Bolt-return rails to make an easy return-fuel system. $45 shipped. Part off car.
OEM Lexus 3VZ-FE Return-Fuel Rails
Anodized aluminum and drilled/tapped for 12x1.25 fittings on all four sides. These didn't line up perfectly on my intake manifold. $35 shipped. Part off car.
Re: AKORA12's MASSIVE PARTOUT3
Postby aennes » Mon Sep 27, 2010 3:41 pm
How about the door handle, driver's side, exterior? How much you want for it?
aennes
Postby akora12 » Mon Sep 27, 2010 5:53 pm
aennes wrote:How about the door handle, driver's side, exterior? How much you want for it?
I'm only selling performance parts for now.
Postby akora12 » Mon Sep 27, 2010 6:05 pm
Lip kit, muffler and knock sensor kit sold.
Postby SirThomas88 » Tue Sep 28, 2010 10:12 pm
What about your boost gauge elbow fitting and the line? Selling that by chance?
SirThomas88
Postby akora12 » Wed Sep 29, 2010 5:11 am
SirThomas88 wrote:What about your boost gauge elbow fitting and the line? Selling that by chance?
I'm selling the elbow with the s/c and the line with the gauge. I'm trying to keep everything as they originally came in the box as new. Thanks!
Postby akora12 » Thu Sep 30, 2010 7:20 am
Idler pulley sold.
I'm open to offers on the motor, s/c, wheels/tires and engine mounts. All else is still at the price listed.
Postby akora12 » Wed Oct 06, 2010 1:47 pm
Uggh, I already can't edit this post. I really don't want to make a fourth...
Here's a pic of the supercharger removed. It's on ebay now as well. Enjoy!
Postby aigochamaloh » Sun Oct 17, 2010 7:48 pm
Did you end up selling your SC?
aigochamaloh
Postby akora12 » Tue Oct 19, 2010 4:47 pm
Supercharger and oil pressure gauge sold.
Postby GreeKAvaLoN » Tue Oct 19, 2010 6:39 pm
soo what are you doing with ur body/shell? yes i'm persistent i know lol.
GreeKAvaLoN
Postby 02slera » Fri Nov 19, 2010 7:13 am
payment sent for calipers... tracking # received.
cant wait to get them installed. (i suspect one of my oem calipers may be sticking a bit)
will save up some more, im interested in the fuel mod, and the injectors.
2002 Solara SLE v6
02slera
Postby akora12 » Fri Nov 19, 2010 7:34 am
I'm actually surprised the injectors haven't sold yet. They are a direct drop in, and basically new after the cleaning and flow testing. They have new o-rings and grommets as well.
Postby ecms171 » Sun Nov 21, 2010 11:15 pm
interested in fuel parts; jims fuel mod and parts, Return fuel rail and injectors. Still got them?
Bone stock 1MZ Camry
Hoping to be boosted(TURBO)
ecms171
Postby akora12 » Mon Nov 22, 2010 6:19 am
ecms171 wrote:interested in fuel parts; jims fuel mod and parts, Return fuel rail and injectors. Still got them?
Yes.
