SolaraGuy.com • View topic - AKORA12's FINAL PARTOUT
Postby akora12 » Sun Dec 12, 2010 4:35 pm
This is the last of my items for sale. I've reduced the price on everything in hopes for a quick sell. I'm open to offers, but please keep in mind that these prices are very fair IMO.
Also, please add 2.9% for PayPal fees.
XERD Headers
Only set of long-tube headers ever made available for the 1MZ-FE. These were recently welded to seam up two small holes the previous owner had. I've owned the OBX and JPP headers, and these were by far better than both in build quality and design. $700 shipped.
Greddy Oil Adapter
Bought new and used for less than 3k miles. Bolts to oil filter fitting and accepts many ports for oil pressure/temp. gauge. $40 shipped.
Poly Engine/Tranny Mounts
Front motor mount and tranny mount. $350 shipped for both, or $175 shipped a piece. The rear bushing was destroyed during removal from the mount.
Pulley Boys 9 psi Supercharger Pulley—Black
Brand new. $50 shipped.
TRD Alternator Bolt
Brand new authentic TRD piece. Very rare! $25 shipped.
Jim’s Fuel Mod
Used for 13k miles. Features custom-ordered black hoses. $65 shipped.
Jim’s Fuel Lines/Fittings
Brand new -6AN lines custom made by Jim to match my black fuel mod kit. Includes a 24" hose and 16" hose with female fittings. I will also include two -6AN to 12x1.25mm fuel rail fittings. $45 shipped.
Jim’s Torque Rod
Includes black insulators on unit and for lower mount to prevent noise. $40 shipped.
OEM Wheel Locks
Factory Toyota locks with key. $35 shipped.
VDO Fuel Pressure Gauge
Brand new. Features a black face with red needle. 0-100 psi reading. Will work great on the Aeromotive FPR or as a stand-alone piece within the fuel mod. $25 shipped.
Centric Front Supra Rotors
Used for 3k miles. Has black-coated hubs, vanes and area caliper doesn't clear so NO rust will be present on areas not touched by pad. RH rotor has a very minor surface scrape from one of the pad clips, but should work out with use. $50 shipped.
Centric Rear Solara Rotors
Used for 3k miles. Has black-coated hubs and vanes so NO rust will be present on areas not touched by pad. These are in excellent condition and still have the factory turn marks. $65 shipped.
OEM LH Axle Hub
Bought as a replacement from a vehicle with 72k miles. Includes ABS sensor. $65 shipped.
OEM Engine Cover
Professionally painted by a body shop at the time I had my kit painted. It has 3 coats of silverstream opalescent and 2 of clear. Used for less than 1k miles. $100 shipped.
OEM Gen. 4 Camry Return-Fuel Rails
Bolt-return rails to make an easy return-fuel system. $45 shipped.
OEM Lexus 3VZ-FE Return-Fuel Rails
Anodized aluminum and drilled/tapped for 12x1.25 fittings on all four sides. These didn't line up perfectly on my intake manifold. $35 shipped.
Re: AKORA12's FINAL PARTOUT
Postby cartang » Sun Dec 12, 2010 5:57 pm
Akora I sent a email ( about TRD boost gauge) Thanks
[IMG]http://i275.photobucket.com/albums/jj307/cartang1/007-2-1.jpg[/IMG]
Camry 99, 5sp manual, SC,CPE intake,OBX headers, Jim's fuel system,Walbro pump,Greddy exhaust,Exedy 1 clutch,Fidanza flyweel.
Camry 07, V6,TRD cat back,Fujita CAI, GS 430 rims
cartang
Postby mig0s » Sun Dec 12, 2010 6:04 pm
Pm'd also about Injen. Thanks.
mig0s
Postby Mr_Krispy1183 » Sun Dec 12, 2010 8:05 pm
Big vouch for Ryan, another stand-up SG whose car's "demise" has come too soon :(
Postby pwizzle » Mon Dec 13, 2010 1:09 am
Sorry if this has been covered before, but what's the advantage of having Jim's Fuel Mod on a N/A 1MZ?
"To be is to do" - Plato
"To do is to be" - Sartre
"Do be do be do" - Sinatra
pwizzle
Postby akora12 » Mon Dec 13, 2010 6:29 am
pwizzle wrote:Sorry if this has been covered before, but what's the advantage of having Jim's Fuel Mod on a N/A 1MZ?
Not much, but you'll get some added knock protection since the kit evens out the fuel delivery to each rail.
Postby akora12 » Mon Dec 13, 2010 6:44 am
Mr_Krispy1183 wrote:Big vouch for Ryan, another stand-up SG whose car's "demise" has come too soon :(
Thanks, Brian. It's been tough to give up on the solara, but I'll be keeping her as a second car to have fun with. I'll probably go with the low and slow theme once the boat is paid off.
Postby Solarasian » Mon Dec 13, 2010 7:05 am
its stinks not having money... i want headers...
Auto SLE V6
6000k VVME Bi-Xenon
GReddy SP2 catback
injen SRI is2030p
Kaminari Lip Kit(stand by)
Tokico hp Struts
Tein S Tech
Solarasian
Postby SirThomas88 » Mon Dec 13, 2010 2:21 pm
I'm interested in the Fidanza and the 9psi pulley. Sending you a PM now.
SirThomas88
Postby a94autocamry » Mon Dec 13, 2010 8:46 pm
Might be interested in the Supra injectors...how many cc's are they?? and the part # ?? Direct fit into our 1mzfe motors or modifications needed??
slow white = "no show and no go"
a94autocamry
Postby akora12 » Mon Dec 13, 2010 8:57 pm
a94autocamry wrote:Might be interested in the Supra injectors...how many cc's are they?? and the part # ?? Direct fit into our 1mzfe motors or modifications needed??
325cc. Denso part #23250-46050. Unlike the brown-top injectors, these are a perfect fit with the included new o-rings and grommets.
Postby a94autocamry » Tue Dec 14, 2010 12:56 am
you got pm :)
a94autocamry
Postby SirThomas88 » Tue Dec 14, 2010 3:05 am
akora12 wrote:325cc. Denso part #23250-46050. Unlike the brown-top injectors, these are a perfect fit with the included new o-rings and grommets.
Wow those are big injectors. I've got the 305cc injectors and boosting 5.5psi with a Walbro 255 pump I have my SAFC2 reducing fuel around -22%
SirThomas88
Postby akora12 » Tue Dec 14, 2010 6:43 am
The 255 probably has something to do with that. I only had to pull around -12% at 6 psi with a Walbro 190.
Postby akora12 » Tue Dec 14, 2010 6:44 am
Flywheel and intake sold.
