SolaraGuy.com • View topic - FS: Akora12's Scraps
Postby akora12 » Sun Feb 20, 2011 2:17 pm
These are the lowest prices I'll go before these items hit the trash.
Greddy Oil Adapter
Bought new and used for less than 3k miles. Bolts to oil filter fitting and accepts many ports for oil pressure/temp. gauge. $35 shipped.
Pulley Boys 9 psi Supercharger Pulley—Black
Brand new. $30 shipped.
Jim’s Torque Rod
Includes black insulators on unit and for lower mount to prevent noise. $30 shipped.
OEM Wheel Locks
Factory Toyota locks with key. $25 shipped.
VDO Fuel Pressure Gauge
Brand new. Features a black face with red needle. 0-100 psi reading. Will work great on the Aeromotive FPR or as a stand-alone piece within the fuel mod. $15 shipped.
Centric Front Supra Rotors
Used for 3k miles. Has black-coated hubs, vanes and area caliper doesn't clear so NO rust will be present on areas not touched by pad. RH rotor has a very minor surface scrape from one of the pad clips, but should work out with use. $40 shipped.
Centric Rear Solara Rotors
Used for 3k miles. Has black-coated hubs and vanes so NO rust will be present on areas not touched by pad. These are in excellent condition and still have the factory turn marks. $50 shipped.
OEM LH Axle Hub
Bought as a replacement from a vehicle with 72k miles. Includes ABS sensor. $50 shipped.
OEM Engine Cover
Professionally painted by a body shop at the time I had my kit painted. It has 3 coats of silverstream opalescent and 2 of clear. Used for less than 1k miles. $100 shipped.
OEM Gen. 4 Camry Return-Fuel Rails
Bolt-return rails to make an easy return-fuel system. $35 shipped.
OEM Lexus 3VZ-FE Return-Fuel Rails
Anodized aluminum and drilled/tapped for 12x1.25 fittings on all four sides. These didn't line up perfectly on my intake manifold. $25 shipped.
Re: FS: Akora12's Scraps
Postby akora12 » Mon Feb 21, 2011 9:16 am
TRD alternator bolt sold.
Postby ToyoSolV6 » Mon Feb 21, 2011 9:18 am
both supra rotors for $40? and will the rotors fit with the stock calipers and brackets?
Postby akora12 » Mon Feb 21, 2011 9:40 am
ToyoSolV6 wrote:both supra rotors for $40? and will the rotors fit with the stock calipers and brackets?
No, these will only work with the supra bbk kit.
Postby addy287 » Tue Feb 22, 2011 1:12 am
How much is shipping for the torque rod to Sydney Australia, 2076??
addy287
Postby akora12 » Mon Feb 28, 2011 6:41 am
Greddy oil adapter and VDO oil pressure gauge sold.
