SolaraGuy.com • View topic - "99-"01 Custom OEM Grill
Postby 1st Gen Sol » Wed May 25, 2011 5:36 pm
Wussup guys. I got a custom OEM grill made up that I wanna get rid of. The only thing missing is the mesh and paint. It's currently primered black and ready for paint, all of the prep work is done and any seems on the grill have been filled. The grill itself is not broken or cracked, the tabs are in tack as are the bolt holes. The only thing that is cracked is the grill reinforcement which is not a big deal. Prior to me getting it, the original owner sent it out to me like that (you can either use the one out of your grill or leave the one included on there b/c it's glued back together).
*This is not a Renova or Sarona grill. It is OEM and pretty durable as it is plastic.
I'm looking for $80 bux shipped out to you for the grill.
Thanks for looking. 8)
Here are a few pics of the grill.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Re: "99-"01 Custom OEM Grill
Postby 99BlackSandv6 » Thu May 26, 2011 10:11 pm
I'm a little confused. Were the upper tabs just cut off?
Postby 1st Gen Sol » Thu May 26, 2011 10:18 pm
The tabs to bolt down the grill are still in tact. If your referring to the tabs that go up and down the front of the grill, those were cut off and sanded flat and the outline indent around the grill was filled in to be flush with the rest of the grill.
I just wanted to put it out there if anyone is interested b/c it's just another spare part of the car I have laying around taking up space.
Reasonable offers will also be taken into consideration thru PM's. 8)
1st Gen Sol
Stock Sleeper
Stock Sleeper
