SolaraGuy.com • View topic - Big Brake Kits Solara/Gen4
Postby EricSol » Tue Sep 09, 2003 8:10 pm
While my car has been down with a blown up charger I have been busy designing a Big Brake Upgrade. Its a caliper relocation kit that uses Supra rotors, they are 48mm bigger in diameter and 2mm thicker so its a bit of a squeeze getting the pads on but mine fit no problem. I am going to take some picks of the install and throw up a quicky page on how to install.
I have finalized the prices and the kits are ready to ship.
1) $150 CNC Machined Billet 2024 Aluminum Brackets with grade 10.9 hardware.
2) $400 As above with plain/slotted/dimpled zinc platted rotors.
3) $550 As above with matching rear plain/slotted/dimpled rotors.
The front rotors are made by Ikuta (high quility Japanese) and the rears are Brembos. If you want option 2 or 3 its about 5 days lead time on the rotors so if you order now you should recieve the kits as soon as they are ready. The brackets are cut and ready.
2004 Pontiac GTO 408ci 535 whp all motor
1999 Solara 296 whp
EricSol
Postby EricSol » Tue Sep 09, 2003 8:12 pm
Before; with the old front rotor, look at all that gap.
After; with the new big rotor, now thats more like it.
The stock sized front rotor is pictured on the left with the new bigger rotor beside it, the new rotor is 48mm bigger!
1999 Solara 296 whp
EricSol
Postby LifeguardSLE V6 » Wed Sep 10, 2003 7:30 pm
would the kit somehow fit under the stock rims?
1999 Solara SLE......Lowered courtesy of Eibach and Tokico.
I put the PRO in procrastination!
LifeguardSLE V6
Postby JoeB » Wed Sep 10, 2003 7:43 pm
Eric, do I understand correctly that for $550, you get all parts to do 4 wheels? Do you need or would you recommend a certain pad? Is there anything else that needs to be changed to do this? Thanks, -JoeB
JoeB
Postby EricSol » Wed Sep 10, 2003 9:16 pm
JoeB wrote:Eric, do I understand correctly that for $550, you get all parts to do 4 wheels? Do you need or would you recommend a certain pad? Is there anything else that needs to be changed to do this? Thanks, -JoeB
Its $550 for all 4, but only big in the front. The rears are stock sized. I'm using KVR's all the way around and I'm happy with them but it seems like people have really been liking the Potorfields too, although I don't know if they make rears. My only advice is to run the same compound front and rear.
1999 Solara 296 whp
EricSol
Postby Mole » Wed Sep 10, 2003 10:43 pm
would it be possilble to fit solara front rotors on the rear?
Postby DavPak » Thu Sep 11, 2003 6:07 am
TRDMole177 wrote:would it be possilble to fit solara front rotors on the rear?
nope. since toyota uses a seperate emergency brake system (drum/shoe; housed inside the rear rotors), they physically won't fit. you'd have to modify your car such that the e-brake is disabled.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Mole » Thu Sep 11, 2003 12:53 pm
doh! oh well...
Postby Yanks0114 » Thu Sep 11, 2003 4:20 pm
Porterfield does have front and rear pads
Eric, any intentions to make a kit for the rear also
Postby EricSol » Thu Sep 11, 2003 4:21 pm
Heres a pic of the Billet Brackets.
1999 Solara 296 whp
EricSol
Postby JoeB » Thu Sep 11, 2003 5:17 pm
Hmmmmm, I'm really just not sure.... Spend $2,000-3,000 on a big brake kit or $550 for big brake kit and better brakes for the rear.... :crazyeyes:
Keep me posted I'm very interested in the full setup! Workmanship looks great too! Of course I didn't expect any less... :wink:
I don't know too much about the different metals so this might sound like a dumb question, will they stay nice and shiny like that or will they look all dark and dirty looking after a short period? Maybe all rotors get like that after a while... -JoeB
JoeB
Postby EricSol » Thu Sep 11, 2003 6:02 pm
JoeB wrote:Hmmmmm, I'm really just not sure.... Spend $2,000-3,000 on a big brake kit or $550 for big brake kit and better brakes for the rear.... :crazyeyes:
It will be awhile for the rears, there is no off the shelf rotor I can use (that I have found yet).
1999 Solara 296 whp
EricSol
Postby swimshady906 » Thu Sep 11, 2003 10:07 pm
LifeguardSLE V6 : It does'nt look like it. I'm wondering the same thing... because I use my stockies for auto-x ... cheaper tires on a 16 than 18 :D
02' S2000 Silverstone
swimshady906
Postby boneezy » Fri Sep 12, 2003 12:55 am
im not sure what im looking at here, what are the billet brackets for?
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby EricSol » Fri Sep 12, 2003 6:16 am
j0hn19 wrote:im not sure what im looking at here, what are the billet brackets for?
Those are the brackets that relocate your calipers outboard to accept the larger rotor pictured above.
1999 Solara 296 whp
EricSol
