SolaraGuy.com • View topic - FS: OEM and Performance Parts
Postby akora12 » Mon Jul 09, 2012 9:10 am
I still have this stuff laying around and need it out of my house.
OEM Wheel Locks
Factory Toyota locks with key. $25 shipped.
Centric Front Supra Rotors
Used for 3k miles. Has black-coated hubs, vanes and area caliper doesn't clear so NO rust will be present on areas not touched by pad. RH rotor has a very minor surface scrape from one of the pad clips, but should work out with use. $40 shipped.
Centric Rear Solara Rotors
Used for 3k miles. Has black-coated hubs and vanes so NO rust will be present on areas not touched by pad. These are in excellent condition and still have the factory turn marks. $50 shipped.
OEM LH Axle Hub
Bought as a replacement from a vehicle with 72k miles. Includes ABS sensor. $50 shipped.
OEM Timing Gear. $20 shipped.
Great shape. Just the one.
OEM Gen. 4 Camry Return-Fuel Rails
Bolt-return rails to make an easy return-fuel system. $35 shipped.
OEM Lexus 3VZ-FE Return-Fuel Rails
Anodized aluminum and drilled/tapped for 12x1.25 fittings on all four sides. These didn't line up perfectly on my intake manifold. $25 shipped.
OEM Fuel Pump. $15 shipped.
OEM Gen. 2 Lug Nuts. $25 shipped.
Used on all newer-style Toyota wheels.
H3 capsules with shield (2). $45 shipped.
I slightly modified the base of these to fit in the gen. 1.5 fogs, but they can be retrofitted in just about anything. The shield can also be cut off with a dremel if needed. These will work with 9006 bulbs.
Mercedes E-Series H3 capsules (3). $65 shipped.
Genuine Mercedes glass capsules. Will fit 9006 bulbs.
JDM Acura capsules (2). $25 shipped.
I'm not 100% sure what bulb these fit, but they can be modified for whatever.
9006 capsules without base (2). $15 shipped.
These are ultra light and can be affixed with silicone.
Auto EGR Cooler. $20 shipped.
Swap this if you don't have the proper EGR tube with your s/c
OEM Water Pump. $25 shipped.
Used for 20k miles.
OEM Oil Pump. $25 shipped.
Used for 20k miles.
OEM Clutch Throwout Bearing. $20 shipped.
Used for 3k miles.
OEM Timing Belt. $15 shipped.
Used for 3k miles.
Snow Performance 2 Qt. Water/Meth Reservoir. $15 shipped.
New!
Re: FS: OEM and Performance Parts
Postby SolaraPete » Mon Jul 09, 2012 6:57 pm
Hey whats up Akora - what are you driving these days?? GLWS!!
SolaraPete
Postby HARKEM » Mon Jul 09, 2012 8:20 pm
PM'D
I'll take the 9psi Pulley.
2001 V6 CAMRY TOURING
DBA 4000 Slotted/Cross Drilled Rotors Front/Rear, EXEDY Stage 1 Race Clutch, FIDANZA 9lbs Flywheel,
Whiteline RSB & FSB, TRD Suspension, CUSTOM Headers&OBX CatBack, TRD S/C:)
HARKEM
Postby akora12 » Tue Jul 10, 2012 5:15 am
SolaraPete wrote:Hey whats up Akora - what are you driving these days?? GLWS!!
Hey Pete! Here's my new rides...Armada LE and Silver Nautique 2001:
Postby akora12 » Tue Jul 10, 2012 5:47 am
HARKEM wrote:PM'D
PM back!
Postby trd4life » Wed Jul 11, 2012 8:07 am
i'll take the meth tank man.
Postby akora12 » Wed Jul 11, 2012 9:00 am
trd4life wrote:i'll take the meth tank man.
It's yours, gabe. Let me know if you don't still have my contact info.
Postby KingKevin » Wed Jul 11, 2012 7:58 pm
Do you have relocation brackets to go with the supra rotors by any chance?
2001 SE V6
Injen intake w/ extension - Renova Grill - custom catback exhaust - 2 12" Kenwood subs - Tein s tech - neons - 8000k headlights - 3000k fogs
KingKevin
Postby akora12 » Thu Jul 12, 2012 4:05 am
KingKevin wrote:Do you have relocation brackets to go with the supra rotors by any chance?
Sorry, those sold a long time ago.
Postby KingKevin » Thu Jul 12, 2012 7:48 pm
Oh well figured I would ask just in case. anyways GLWS
2001 SE V6
KingKevin
Postby colombiantuner » Fri Jul 27, 2012 7:01 pm
Hi
Do you still have the 9006 yellow capsules?
colombiantuner
Postby akora12 » Sun Jul 29, 2012 8:03 am
colombiantuner wrote:Hi
I have the ones without bases and the e-series set.
Postby colombiantuner » Tue Jul 31, 2012 8:09 pm
Please give an email address so I can contact you to coordinate payment and shipment. Thank you
colombiantuner
Users browsing this forum: No registered users and 84 guests
