SolaraGuy.com • View topic - FS Exedy OEM Clutch Kit and F1 Chromoly Flywheel 4Cyl [CA]
Postby grimpy » Thu Aug 09, 2012 11:44 pm
Brand new. Exedy OEM clutch kit with F1 Racing Chromoly flywheel.
Fits Scion TC, Camry, Solara, Rav4
This is a brand new genuine Exedy standard direct replacement clutch kit. This clutch kit contains all the necessary components to do your clutch replacement and is the perfect setup for any stock or lightly modified vehicle. Exedy Globalparts Corporation was founded in 1923 and its clutch manufacturing business and prominent brand name Daikin Clutch are known throughout the world for supplying quality powertrain products. Exedy supplies to all 11 vehicle manufacturers in Japan as well as many other vehicle manufacturers including SCION. Exedy is the largest clutch manufacturer in Japan and their name stands for the highest in quality and performance.
    Our genuine EXEDY clutch kit includes:
  • Exedy Pressure Plate
  • Exedy Clutch Disc (9-1/4" , 21 spline)
  • Release Bearing
  • Pilot Bearing
  • Alignment Tool
  • Installation Guide
F1 Racing Lightweight Chromoly Flywheels are made from 4140 one-piece forged chromoly steel. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibility of seperating from the flywheel. All F1 Racing Chromoly flywheels have passed engineering tests to 12,000 rpm.
  • Ultra Light and weighs only 11.4 lbs
  • Meets or exceeds SFI 1.1 specification
  • Mde from 4140 forged chromoly steel (2X stronger than billet steel)
  • F1 Racing Chromoly Flywheels incorporate special design features to enhance airflow for improved clutch cooling and performance
  • F1 Racing Chromoly Flywheels work with every clutch including Exedy, ACT, Fidanza, Clutchmasters, and other direct replacement clutch kits
  • CAD designed, CNC machined and computer balanced
TYK1505-SS; 56029FX-HT #29
2005 - 2010 Scion tC (2.4L DOHC 4cyl)
2002 - 2006 Toyota Camry (2.4L DOHC 4cyl)
2002 - 2007 Toyota Solara (2.4L DOHC 4cyl)
2004 - 2006 Toyota RAV-4 (2.4L DOHC 4cyl
$250 picked up in SOCAL! Paid over $315 including tax. Email grimpydsc@gmail.com
grimpy
Users browsing this forum: No registered users and 76 guests
