SolaraGuy.com • View topic - 1MZ-FE Supercharger for Sale
Postby gnaw_divad » Thu Nov 20, 2014 3:54 pm
Been considering this for a long time but finally time to get rid of the car.. been on here for years.
I'm considering parting out the supercharger (automatic) but not sure how much it's worth now and days. Car only has about 100K miles but I don't believe I put the charger on until about 60K. Installed by Toyota of Palo Alto so if you're interested you'd have to help me take it off.
* I have a sidebar question. I went to my mechanic and they mentioned that if I took off the charger, I would have to reprogram the cars' computer. Is this true? If not, I can just have him remove it.
Also, if someone is interseted in the car as a whole, that would be even better.. I can post pics.
gnaw_divad
Re: 1MZ-FE Supercharger for Sale
Postby HARKEM » Fri Nov 21, 2014 2:03 am
Unless you had the stock computer changed or chip'd it'll be fine after a couple of hundred km's.
Are you still running the stock 4psi pulley?
2001 V6 CAMRY TOURING
DBA 4000 Slotted/Cross Drilled Rotors Front/Rear, EXEDY Stage 1 Race Clutch, FIDANZA 9lbs Flywheel,
Whiteline RSB & FSB, TRD Suspension, CUSTOM Headers&OBX CatBack, TRD S/C:)
HARKEM
Postby gnaw_divad » Tue Nov 25, 2014 1:19 pm
Hi,
I'm running the 5.5 PSI
gnaw_divad
Postby JavaJoe_2 » Sat Nov 29, 2014 3:31 pm
Unless you altered anything other than putting on the s/c'er, the computer will reset itself to factory settings after you remove battery power.
Got Boost?? :sweet:
JavaJoe_2
Postby oceanax13 » Tue Dec 09, 2014 9:23 am
I sent you a PM a few days ago
oceanax13
Postby 1kdude » Mon Jul 20, 2015 6:03 pm
Hello,
Let me know if this is still available, I am in the Bay Area and might be interested.
Cheers,
1kdude
