SolaraGuy.com • View topic - WTB: RSB
WTB: RSB
WTB: RSB
Postby solaraguy777 » Thu Jan 01, 2004 6:52 pm
IF any one has a rear sway bar, im just getting my tokico/eibach suspension done, so i am also looking for a used rsb thanx
Ram air intake w/ k&N filter, Trd exhaust,
Hp racing evo 18's, Tokico/Eibach combo.
solaraguy777
Postby TadS » Thu Jan 01, 2004 7:09 pm
I have one, but it's not for sale. :P
Really they're pretty cheap.
For the best price on the Whiteline bar you can check CTM ($130 shipped). For the TRD bar it's a bit more, and I am not sure where you would get one for the lowest price. Good luck finding a used one, I am just not sure it's worth the effort, as the cost of a new one is pretty low.
TadS
Postby Mole » Thu Jan 01, 2004 10:24 pm
i got my TRD RSB from toyotaparts4u.com
Postby Yanks0114 » Thu Jan 01, 2004 11:56 pm
I spoke to eddie from kinderhook toyota and he did it for $150 shipped. Best deal around.
If you decide to go new, talk to eddie.
Postby solaraguy777 » Fri Jan 02, 2004 9:58 am
k thanx for all the help , yea i guess it worth the extra cash just to get a new one.
solaraguy777
Postby kondo » Fri Jan 02, 2004 12:30 pm
paid $150 for mine off toyotaparts4u. The only downfall of it is you have to be carfull about scraping it if you are lowered. I have had to get mine reajdusted once because a shop put my car a lift and it screwed up the RSB so that it was not centered, but the performance you get from upgrading is worth it.
Nick
kondo
SolaraGuy StickerGuy
Postby Mole » Fri Jan 02, 2004 9:19 pm
how on earth can a correctly installed RSB scrape?
Postby TadS » Sat Jan 03, 2004 12:27 am
TRDMole177 wrote:how on earth can a correctly installed RSB scrape?
Yeah. I kind of thought that too?!? It seems sort of impossible.
TadS
Postby indiglosolara » Sat Jan 03, 2004 2:07 am
that kinda weird.. scraping on a RSB???? i have mine installed and on track setting and i packed 4 ppls in the back of my car with my wheels tucking on tein and tokicos.. never have i scrape even going over a speed bump.... and dips..
are you sure the installed was correct....
indiglosolara
Solara 2 xB
Solara 2 xB
Postby xyntax » Sat Jan 03, 2004 9:36 am
I'm starting to have the squeeking problem now. Damn it, I wish it would stop raining so I could work on this. I'm too lazy right now, can anyone recap on the best way to repatch this squeeking problem and make it go away forever?
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby kondo » Sat Jan 03, 2004 11:36 am
When the car shop put my car on a lift is scrwed it up. The same thing happened when I went to jiffy lube my car actally go high cented I had to burn out in reverse to get my car unstuck.
Lowered solara pluss greddy exhaust and 100 lbs of stereo crap in the trunk equally scraping on everything.
Nick
kondo
Postby solaraguy777 » Sat Jan 03, 2004 1:02 pm
I also got a question , sice were bringing up rubbing, i have 18x8 rims w/ my rims beeing that wide when i put ont the tokicos and eibachs will the wheel scrape??
solaraguy777
Postby Peter » Sat Jan 03, 2004 1:26 pm
yes they will scrape the fender. u have to either get them cut or rolled. btw, do u need tires for those rims?
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby solaraguy777 » Sat Jan 03, 2004 1:31 pm
no i already got some p-zero's on them , is it expensive to get them rolled or cut? has any1 had to do this? is it something i can do at home?
solaraguy777
Postby SolaraT » Sat Jan 03, 2004 1:47 pm
Just take off your whe :fadein: els and start tucking, rolling, / cutting.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
