SolaraGuy.com • View topic - The "Ultimate" Solara For Sale-
Postby flybigjet » Wed Mar 17, 2004 12:15 am
I’ve finally decided to put my 1999 Toyota SE-V6 Solara up for sale as I’m in the process of special ordering a 2004 BMW M3 and am going to need the garage space- I can't bring myself to be a single guy with four cars- that's a little too much transportation overkill.
I have been the only owner and driver- the car was special ordered in 10/98 and delivered in 02/99. There is no rust, body damage, or major door dings and the car has always been garaged and waxed with Zymol- there are some expected paint chips on the front bumper and body and a very superficial "cat-scratch" on the passenger's front quarter panel. The car has never been in an accident, tracked, raced, auto-crossed, or run in the quarter mile. The engine has never had an over-rev'ed, and has never had any problems with either O2 sensors or OBD-II codes. Milage is approximately 26,400. The car was DynoJetted at (SAE corrected) 261.1 front wheel horsepower and 265.5 pound-feet of torque on 91 octane fuel. DynoJet was performed with a stock exhaust (from the cat back)- the GReddy cat-back had not been installed yet. The car passes Colorado smog on a rolling dyno (almost as painful as California) with no problems.
Total costs of upgrades/modifications well exceed the original purchase price of the car. Receipts of work done are available on request.
The car is mechanically perfect, and I firmly believe that this is the car that Toyota *should* have built- you won't realize how fast it is until you scare yourself and it handles like it’s on rails. The ride is firm but very settled- all suspension components work together seamlessly. It makes a very comfortable highway cruiser but turns into a completely different car once you let it loose on the twisties. There is *nothing* on the car that does not work perfectly- engine, electrical, lighting, or body. Any modifications were done at a level that exceed factory fit and finish. All work was done by myself, the dealership, or a performance shop specializing in Asian imports. The car has been *very* well taken care of- I would use it for my daily driver except that owning two coupes (and eliminating my hatchback) is not conducive to a Colorado lifestyle (mountain biking, skiing, boarding, rock climbing, etc.).
Note: The S-AFC must be dyno-tuned and the 7 lb. pulley replaced with a 5.5 lb. one (provided at time of sale) after the car leaves Colorado. The car (and boost resulting from the smaller pulley and associated S-AFC settings) are optimized to make the equivalent of 5.5 lbs of sea level boost at 5500’.
The OEM air intake assembly, hood, floor mats and shifter knob are also included in the sale. The buyer will be responsible for shipping the OEM hood (box and packing will be provided). A 5.5 lb. pulley is also provided to replace the current 7 lb. pulley to generate the equivalent amount of boost at sea level as the car is tuned for at 5500’.
The tires are virtually brand new and have less than 500 miles on them. All four wheels have been professionally refinished and clearcoated, and are completely free of curb rash. The car was set to factory recommended alignment specifications following wheel purchase by a manual four wheel alignment. Struts were custom slotted to allow proper reset of the camber due to lowering the car.
Price: Negotiable- reasonable offers only please. There is no urgency to sell as I will not be receiving my new car until mid-summer (and can always sell another of my cars if I have to- so no “fire-sale” prices). A one-way ticket to Denver, CO (vehicle location) from anywhere serviced by United Airlines is may be provided on a case-by-case basis. Please email me privately at flybigjet@earthlink.net for pricing discussions.
For pictures, go to http://www.cardomain.com/id/flybigjet . The pictures do not show the new VIS Racing CF hood nor the black TRD floor mats, and in all honesty, do not do the car justice. I’ll try to take more pictures tomorrow.
More detailed pictures and information are available on request. Please email me at flybigjet@earthlink.net .
One final note: The car is for sale as a whole. Individual parts ARE NOT for sale- I *will not* be parting out the car, so please don’t ask for individual pricing.
1999 Toyota Solara SE V-6
Flame Red/Charcoal Leather/5-Speed Manual
Drivetrain/Powerplant
- Toyota Racing Development (TRD) 1MZ-FE supercharger
- 7 lb. supercharger pulley (5.5 lb. pulley provided at time of sale)
- TRD automatic belt tensioner/drive assembly
- Denso Iridium spark plugs
- Magnacor Racing spark plug wires
- Ignition Solutions Plasma Booster
- TRD short-throw quickshifter
- TRD limited-slip differential
- ClutchMasters Stage III clutch
Fluids/Lubricants
- Redline LSD friction modifier
- Redline manual transaxle fluid
- Motul RBF-600 dot-4 brake fluid
- Redline WaterWetter
- Mobil 1 synthetic oil
- Mobil 1 synthetic oil filter
- Energy Suspension bushing lubricant
Intake/Exhaust
- Millen Motorsports intake system
- 7.5” K&N cone filter w/ velocity stack
- Greddy Evolution Cat-back exhaust
- Cattman Performance y-pipe w/ high-flow catalytic converter
- Welded O2 sensor dyno port
Suspension/Wheels/Tires/Brakes
- TRD front strut tower brace
- TRD rear anti-sway bar
- Energy Suspension sway bar bushings/brackets
- Whiteline front anti-sway bar
- Eilbach progressive-rate springs
- Bilstein mono-tube shocks
- Custom slotted camber-adjustable strut mounts
- O.Z. Racing Monte Carlo Lightweight 17x8 wheels
- O.Z. Racing carbon fiber center caps
- Rolled/repainted rear fenderwalls
- Sumitomo HTRZ-II 225/45/17 tires
- Front/rear extended length wheel hub bolts
- Front/rear KVR Performance cross-drilled/chamfered disc brake rotors
- Cadmium plating on all brake rotors
- Front/rear Porterfield Racing carbon fiber brake pads
- SMC Performance stainless steel brake lines
- Daytona Yellow/clearcoated brake calipers/torque plates
Electrical/Gauges/Wiring
- Custom rewire from Toyota negative pole to standard pole electrical system
- Optima Deep-Cycle Yellow Top battery
- Monster Cable battery clamps
- Prestolite Wire 4-gauge battery cables
- Nippo-Denso high-output alternator
- SuvLights 100W headlight wiring harness
- Krypton Xenon 3900K 90/100W headlamps
- SuvLights 80W foglight wiring harness
- Hiper Industries Xenon 80W foglamps
- Solar White Xenon headliner lamp
- APC Super Bright parking/front turn, rear turn bulbs
- APC Super Bright stop, license plate, trunk bulbs
- Escort Passport SR-1 X/K/Ka/Laser detector with custom in-tachometer/gauge cluster mounting
- Piezo horn added to lock/unlock controller
- Fiamm high/low tone horns
- Autometer boost gauge
- Autometer EGT gauge
- Autometer tachometer
- A’Pexi Super-Air Flow Compensator custom mounted in headliner assembly
- DynoJet tuning of S-AFC by Paragon Tuning of Denver (261.1 hp/265.5 tq @ wheels--dyno'd before cat-back installation)
Miscellaneous
- Shaved rear “Toyota” logo, side “SE”, “V6” logos
- Autometer 2-gauge A-pillar pod
- Excalibur wheel locks
- O.Z. Racing lockset
- OBX Racing pedal covers
- “Supercharged” quarter panel logos
- VIS Racing carbon fiber hood
- 3M invisible bra
- TRD floor mats
- TRD leather shift knob
- TRD radiator cap
- TRD oil-filler cap
Sound System
- Sony CDX-C910 Mobile ES cd player
- Sony RMX-4S remote control
- Sony U-50D Mobile ES dsp
- Fosgate Punch 600-A4 4-channel amplifier
- Fosgate Punch 1 farad capacitor
- 6” MB Quart 218.03 SX Seperates front/rear speakers
- MB Quart MusiComp Competition crossovers
- Fosgate Punch 150-A2 2-channel amplifier (bridged mono)
- Fosgate Punch 0.5 farad capacitor
- 10” JL Audio subwoofer
- Custom trunk-mounted subwoofer enclosure
- Custom trunk-mounted equipment rack
- V-Block Vibration Dampening Shield
- 4-gauge in-line fuse holder
- 4/8-gauge fuse block
- 4-gauge MonsterCable power lead
- 8-gauge Nakamichi power/ground leads
- 8-gauge Nakamichi braided speaker wire
- Custom tuning by Excalibur Sound of Denver
Also Included
OEM hood (buyer responsible for shipping in provided box)
5.5 lb. supercharger pulley
OEM floor mats
OEM shifter knob
"Do not meddle in the affairs of dragons, for you are crunchy and taste good with ketchup."
flybigjet
Postby Jackass-Jeff » Wed Mar 17, 2004 6:49 am
pretty cocky there saying ultimate solara =P but nice list of mods. I"m sure it'll get sold
Try v6performance.net. It's a big forum w/ various makes so it may be easier to sell than to someone that already owns a Solara
1GR-FE ftw!
Jackass-Jeff
Postby flybigjet » Wed Mar 17, 2004 8:37 am
Actually, "The Ultimate Solara" was the title given to the car by the moderator's over at SC3- never asked for it, but was very appreciative.
Thanks for the tip. I'll post over there as soon as I get some more pics taken. R.
flybigjet
Postby gnegroni » Tue Feb 24, 2009 8:25 pm
So, where are the pics?
gnegroni
Postby Eye8Pussies » Tue Feb 24, 2009 8:30 pm
lol
this thread is 5 years old
Postby gnegroni » Tue Feb 24, 2009 8:35 pm
Eye8Pussies wrote:lol
BUAUHAHAHAHAHAHA!!!!
I guess I'm just way too sleepy! Do I get an award for that?
gnegroni
Postby indiglosolara » Tue Feb 24, 2009 10:03 pm
hahahahahaahaha... holy thread revival batman!!
indiglosolara
Solara 2 xB
Solara 2 xB
Postby ASG14 » Tue Feb 24, 2009 10:10 pm
omfg.....
ASG14
Postby Mr_Krispy1183 » Tue Feb 24, 2009 10:22 pm
Wow, haven't seen Rod's car since the good old Team SC3 days.
Postby QuickSEV6 » Tue Feb 24, 2009 11:07 pm
Mr_Krispy1183 wrote:Wow, haven't seen Rod's car since the good old Team SC3 days.
I remember this guy way back in the Camryman.org days.
I wonder what ever happened to this car.
Postby TxBmbleBee » Tue Feb 24, 2009 11:11 pm
good god the amount of money he dropped aftermarket on this car! i remember him way back in the day i think his solara was red
TxBmbleBee
Postby CamryOnBronze » Wed Feb 25, 2009 6:47 am
FAIL.
Postby Akfahad » Wed Feb 25, 2009 7:19 am
:drinking:
Postby Jakecallun20 » Wed Feb 25, 2009 8:35 am
muahahaha lol. Epic fail
Postby gnegroni » Wed Feb 25, 2009 10:48 am
What can I say, I love reading about modded Gen1-1.5. I still look them up in the local classifieds.
gnegroni
