SolaraGuy.com • View topic - Jbl amp's inifnity perfect subs,clarion head unit
Postby BurningSolara » Wed Apr 14, 2004 2:45 am
In order to know who wants what and in what order it was placed please e mail me first. Tell me what you looking at and what your intersted in doing. I do first come first serve. Blackthought2oo1@aol.com .If everything is purchased together I'll knock off another 100 bucks. :angel:
Pictures can be taken of all the merchandise.
JBL Power P-80.4 $100.00
Multi-Channel Amp
Amplifier Type: Multi-Channel
RMS Power: 40W x 4
Bridged RMS Power: 160W x 2
THD at Rated RMS Power: 0.05%
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: HP/LP
Frequency Response: 10-50,000 Hz
Channel Separation: n/a
Signal to Noise Ratio: >110 dB
Infinity pefect 12 inch sub (two) $220.00
Looking for the “perfect” subwoofer? The Infinity Kappa Perfect 12.1 subwoofer delivers an awesome combination of deep bass and stunning sound quality. The super-rigid drawn-aluminum cone features a curvilinear design and combines with a high roll butyl rubber surround for smooth, efficient bass response all the way down to 18 Hz. Flip the 12.1 over and you’ll marvel at the custom-tooled aluminum basket and huge flared, polished and vented pole piece. The Perfect is designed to deliver kick-butt bass in small sealed enclosures.
Features
Aluminum Cone with Curvilinear Design
High-Roll Butyl Rubber Surround
Precision Die-Cast Aluminum Basket
4-Layer Voice Coil
Subwoofer Specifications
Rec. Sealed Box Dims: 1.00 cu.ft.
Rec. Ported Box Dims: 1.75 cu.ft.
Free Air Usage: not recommended
Sensitivity: 96 dB
Frequency Response: 18-150 Hz
Recommended RMS Power: 350W
Peak Power Handling: 1400W
Impedance: 4 ohms subwoofer wiring options
JBL PowerValve BP-1200.1 $175.00
Subwoofer Mono Amp
Amplifier Type: Mono
RMS Power: 600W x 1 @ 4 ohms
Bridged RMS Power: 1200W x 1 @ 2 ohms
THD at Rated RMS Power: 0.1%
Preamp Outputs: No
Built-In Crossovers: LP
Bass Boost: 0-6 dB
Frequency Response: 10-320 Hz
Signal to Noise Ratio: >100 dB
Clarion 815....... Missing a pixel unless i point it out you wont notice. ( fold out touch screen non dvd player )with 6 disc changer and extra c net cable. It has the clarion DVD Player that works perfectly fine but... It needs new rca's for the center and the sub channel. never got it fixed so i was running stereo therough the head unit which has a dedicated sub left/ rear front/back fade. Unless you want 5.1 dolby that bad you will be fine.
$650
Clarion's VRX815 features a large 7-inch monitor with a fully motorized mechanism that opens at the touch of a button. Once the monitor panel is opened, you can move it either forward or backward in one of three positions to adapt to the shape of the car’s dashboard. The tilt angle can also be adjusted to one of five positions for maximum visibility and to minimize reflections and glare, and the monitor will remember this setting when it is used the next time. Of course, the fully motorized mechanism also stows away the monitor at the touch of a button.
Key Features
Player Type CD
Controller Type CD, MD, TV Tuner ,DVD
Display Type Video
Radio Features
Tuner Type FM/AM Tuner
FM Presets 18
AM Presets 6
Power Specifications
Built-In Power Amplifier Yes
Built-In Amplifier Power 4 x 45 Watts
Dimensions
Depth 6.5 in.
Height 1.94 in.
Width 7 in.
So me placing 10 inch rims on my car will make it handle better? Cool.
BurningSolara
