SolaraGuy.com • View topic - FS: JL Audio e2150 2 Channel AMP
Postby indiglosolara » Mon May 17, 2004 8:34 pm
Hey wasup,
I have a JL Audio e2150 2 Channel AMP for sale. Its in really good condition (like new). Like i have said before. For you that know me know i keep all my stuff in top notch condition.
I have upgraded to a diff amp since i upgraded to diff components also. If you want pics go to www.kennyha.com , I will be asking $160.00 shipped..(to 48 states) Hawaii and Alaska is extra. If you are local and wanna pick up this amp I'm asking $140.00. I have the original box and all manuels. This amp retialed for about $180 new
This amp has only been in my car for about 5 months or so..
I also have some Blaupunkt 6.5 2 way speakers I will give you for free if you get this amp. The 6.5 cost $50.00 when purchased and now im giving it away with the amp.
Specs:
Rated Power (stereo):
45W RMS x 2 @ 4 ohm (12.5V);
75W RMS x 2 @ 2 ohm (12.5V)
Rated Power (bridged):
90W RMS x 1 @ 8 ohm (12.5V);
150W RMS x 1 @ 4 ohm (12.5V)
THD at Rated Power:
<0.08% @ 4 ohm (20 Hz - 20 kHz)
S/N Ratio:
>104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm per ch. / 50 Hz,
>100 @ 2 ohm per ch. / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
9.8" x 9.25" x 2.36"
Features:
Absolute Symmetry™ Class AB Circuit (U.S. Patent #6,294,959)
Differential, Noise-Cancelling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output:
Pass-through type.
Speaker output connections:
accept up to 8 AWG wire
+12V and Ground connections:
accept up to 4 AWG wire
Please PM me with any questions..
Thanks
Kenny
indiglosolara
Solara 2 xB
Solara 2 xB
Postby indiglosolara » Thu May 20, 2004 6:45 pm
bump!!!
indiglosolara
Solara 2 xB
Solara 2 xB
