SolaraGuy.com • View topic - emergency brake light
Ever have a bad experience? Well here's the place to discuss things.
Postby E_funkdoktor » Mon Oct 30, 2006 3:10 am
my emergency light keeps falshing when it isnt suppose to, anyone know how to control that light?
Solara Freak!
E_funkdoktor
Postby Turbosolara » Mon Oct 30, 2006 3:20 am
that means something wrong with your brake system, did you check the fluid level?
you should fix it asap
really
Postby E_funkdoktor » Mon Oct 30, 2006 3:37 am
ok which fluids???
Solara Freak!
E_funkdoktor
Postby Turbosolara » Mon Oct 30, 2006 3:39 am
brake fluid, if it is full and the light blinks, you are in trouble
yo
Postby E_funkdoktor » Mon Oct 30, 2006 3:54 am
in trouble, haha now ur scaring me... what ever soes it MEAN!!!
Solara Freak!
E_funkdoktor
Postby Jon11582 » Mon Oct 30, 2006 8:07 am
It can also mean brake pads are low.
2000 Black Solara SE
Jon11582
light
Postby Sentinel » Mon Oct 30, 2006 9:27 am
I don;t think the light (sensor) can tell if the pads are worn, only that the brake fluid is low; however, this CAN happen when your pads get worn as more fluid is in the brake lines to push the pads out further.
Top off your brake fluid. If that does not fix the probem then investigate the parking brake switch. do you have your parking brake on by a click or 2 accidentally? Open up the console & find th switch. it could be grounding out on something.
If it was an ABS problem then the ABS light would be on, not the brake light.
Sentinel
Postby QuickSEV6 » Mon Oct 30, 2006 10:01 am
I agree with sentinel. It "should" only be that you are low on brake fluid. Even if it looks good enough to you, I suggest you top it off. My light came on, I put in about 2 tablespoons worth and the light never came back on.
Good luck.
Return to Horrible Dealer/Service Rants
