SolaraGuy.com • View topic - maintance done
Ever have a bad experience? Well here's the place to discuss things.
maintance done
maintance done
Postby LostSoul » Tue Jan 13, 2009 6:35 pm
so i went to the dealer (hamer) for maintance and i know they did a tire rotation so when i drive on the freeway my steering wheel shakes a grip why????
LostSoul
Postby 1gSE » Tue Jan 13, 2009 6:43 pm
mostly likely out of balance. Is it only highway?
Solara-M62 @ 5.5psi
1gSE
Postby mazen222 » Tue Jan 13, 2009 6:49 pm
if its your old tires it should not be the balance. Maybe an idiot mechanic bolted the tires on the wrong way. Tire bolts must be tightened crisscross... im 90% sure this is your problem
1999, 5 Speed V6
mazen222
Postby LostSoul » Wed Jan 14, 2009 12:25 am
yeah its only on the highway
LostSoul
Postby 1gSE » Wed Jan 14, 2009 6:23 am
take it to a reputable tire shop, and check the balance on the front wheels....or maybe even all 4, just to be sure. Its common to not have a problem, then suddenly after a tire rotation, start feelin a vibration up front. How long has it been since the last balance?
Solara-M62 @ 5.5psi
1gSE
Postby LostSoul » Thu Jan 15, 2009 12:28 am
1gSE wrote:take it to a reputable tire shop, and check the balance on the front wheels....or maybe even all 4, just to be sure. Its common to not have a problem, then suddenly after a tire rotation, start feelin a vibration up front. How long has it been since the last balance?
three months ago was the last balance could it also be that the front tires waste more than the rear ones ??? so theres one worn out and one that has more thread in front idk?? help will they natrually even out as it goes ???
LostSoul
Return to Horrible Dealer/Service Rants
