SolaraGuy.com • View topic - New Sound System
New Sound System
New Sound System
Postby dvdchris45 » Mon Apr 04, 2005 8:02 pm
Well after about a day and half's worth of work I finally got my sound system. My cousin and I installed it on Fridayafternoon.
-Two 12-inch Sony Xploids Subs @ 2600 watts
-1500 Diesel Audio Amp
Might I also add that I'm running them on the stock head unit and speakers and have had no problems thus far. Guess I underestimated them. Now if I set my BASS on -1 or higher I'll go deaf. Trunk rattle isnt too bad at all but still needs dampening.
Check out my cardomain site for quick glimpse of it. I'll holler when I post some high-res pics. Later!
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Jackass-Jeff » Mon Apr 04, 2005 8:19 pm
Please rate subs at RMS power =P
Peak power = Joke.
1GR-FE ftw!
Jackass-Jeff
Postby dvdchris45 » Mon Apr 04, 2005 9:17 pm
My bad, it is 2600 watts total RMS
1300 watt for each sub.
dvdchris45
Postby Jackass-Jeff » Tue Apr 05, 2005 1:07 am
are you sure? sony doesn't make anything that sophisticated... that power rating is better than the Eclipse titanium and the JL W7
1GR-FE ftw!
Jackass-Jeff
Yeah..
Postby JayDubz » Tue Apr 05, 2005 8:23 am
Yeah that is alot of rms for some sony subs... that has to be peak... they are proably 500rms each, if that....
2000 Galant... Mods in progress!!Image
http://www.cardomain.com/memberpage/350820/
JayDubz
Postby Jackass-Jeff » Tue Apr 05, 2005 10:23 am
1300 Peak
380 RMS
Model: XS-L122P5 (www.xplodsony.com)
RMS power is what you're always using (Continuous Power Handling, as they call it) while Peak is never actually achieved unless you're running full volume/power... There are subs out there (RF one) that are 10,000 PEAK Watts... but the RMS is only like 3,000... which makes 2 "normal" W7 or Titaniums sound 100x better.
What part of California are you from (Nor, So, Central)? I'll show you my 1400 RMS =P
1GR-FE ftw!
Jackass-Jeff
Postby dvdchris45 » Tue Apr 05, 2005 1:22 pm
yeah 380's right. I'm not too poished on my sound system knowledge yet, my bad!
dvdchris45
Return to A/V/N Gen 2 and 2.5
