SolaraGuy.com • View topic - Speaker wires
Speaker wires
Speaker wires
Postby kgzero1 » Wed Dec 21, 2005 5:26 pm
Hi guys,
I would like to know if the wires that power the speakers need to be attached to a specific polarity on the amp. My friend says it doesn't matter. But, I was thinking that this could be one of the sources of the noise I get.
The wires are clear (the insulator), with one that has a blue stripe going through it. The completely clear one is a copper colored wire and the one with the blue stripe is a silver color.
Would the one with the stripe be negative or postitve?
And would having them connected to the wrong place damage the speakers?
Thanks.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby theprodigy79 » Wed Dec 21, 2005 8:51 pm
As long as you have the polarity correct (+amp to +speaker, -amp to -speaker) it should not make a difference. GENERALLY SPEAKING, the pos wire has a stripe running down it, or some other marking (in your case the blue stripe)... but that is more to trace out your connections... Even if you reverse your polarity (+amp to -speaker, -amp to +speaker) it is not damaging, and should not produce any additional "noise"... Your sound staging, however, will not be accurate.
-James
theprodigy79
Postby kgzero1 » Thu Dec 22, 2005 11:20 am
Cool thanks, prodigy!
Man I love this forum and all its helpful people!
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
Postby cklinh » Thu Dec 22, 2005 12:16 pm
On some wires, if you look REALLY REALLY closely, the blue stripe has little horizontal lines on them too... making little pluses...
cklinh
Return to A/V/N Gen 2 and 2.5
