SolaraGuy.com • View topic - How the hell do you remove the rear deck in a gen 2?
Postby Mr. Slippery » Tue Jan 24, 2006 11:13 pm
Well I guess this project won't be finished tonight :x How do I remove the rear deck to replace the speakers? I have the front part loose but it's stuck near the window. I tried prying the little clips out that are inside those oval holes underneath the rear deck lid, and it will not budge. I know it would be a PITA but not this bad. Is there a pdf file somewhere I can look at? Someone help me before I break this thing. :D
-MATT-
Mr. Slippery
Postby DatSRBoi » Tue Jan 24, 2006 11:15 pm
You basicly have to remove the whole back interior to get to them. Im talking about the side ceilings too.
Postby Mr. Slippery » Tue Jan 24, 2006 11:24 pm
I have everything off, and the only part still connected is right up by the window. It seems I have to push it from underneath, but that ain't happening.
-MATT-
Mr. Slippery
Postby kgzero1 » Wed Jan 25, 2006 8:09 am
Is it clearing the child safetey seat hooks? Lift that part up past the hooks and then you just pull it out. The rear deck is the biggest pain in the a$$ to remove.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby Mr. Slippery » Wed Jan 25, 2006 2:36 pm
Yessssss I got it. I had to pull straight back instead of up, and I didn't break anything..............yet. The only problem now, is that the mounts for the new speakers are not the same as the factorys, so I made a couple plates today out of 1/4" mdf. They fit fine, but where the screws attatching the new speakers to the plates are, interfere with the metal frame of the rear deck. So now I have to grind some of it out. What a bitch this is turning out to be.
-MATT-
Mr. Slippery
Return to A/V/N Gen 2 and 2.5
