SolaraGuy.com • View topic - 3-ways components
3-ways components
3-ways components
Postby Aotoyota » Wed Feb 08, 2006 8:40 pm
Wondering if anyone has a set of three ways components in their solara? if so what kind of speakers did you go with and the location of them?
cheers
Aotoyota
Postby Aotoyota » Mon Feb 13, 2006 12:28 am
i guess not? and i guess i may be the first?
Aotoyota
Postby NeFaRiOuS_SLE » Thu Feb 23, 2006 3:12 am
like 3-way speakers? I got 5-way rears, but the front speakers I have to wait until my next paycheck.
Postby theprodigy79 » Thu Feb 23, 2006 7:29 am
Are you speaking of 3-way component speakers (meaning you are going to run 4 channels, and each speaker has a midrange and 2 tweeters), or a 3-way system (meaning your only run two channels instead of 4, but each with a midbass, midrange and high range speaker)?
theprodigy79
Postby Aotoyota » Thu Feb 23, 2006 6:40 pm
3-ways...as in an
8" midbass
3"mid
1"tweet
upfront...and if youre wondering.
Dynaudio System 360 or Alpine F1 components
all tri-amped...no xover.
wondering if anyone has that large of a speaker
array for their front stage already and if so, pics or
where the speakers are.
Aotoyota
Postby theprodigy79 » Thu Feb 23, 2006 8:44 pm
That's what I thought you meant. If you have the money, the Alpine F#1s are the way to go. The 3 ways are some of the best I've ever heard, but a proper setup will run you more than most of the cars on this site are worth... The tri-amping is an interesting approach, but it's a pain in the ass (it will work well, though, if done right). What kind of headunit do you plan to run?
theprodigy79
Postby Aotoyota » Thu Feb 23, 2006 9:24 pm
I current run the old F1 CDA-7990 with the PXA-h900 processor plus dynaudio 240GT system was done for a while but I have the itch to change it. As for triamping, that processor can do everything but cook...so definately not worried with that...
Also considering all new F1 too. any thoughts anyone? suggestions or comments?
cheers
Aotoyota
Postby cam2Xrunner » Thu Feb 23, 2006 11:01 pm
Aotoyota wrote:I current run the old F1 CDA-7990 with the PXA-h900 processor plus dynaudio 240GT system was done for a while but I have the itch to change it. As for triamping, that processor can do everything but cook...so definately not worried with that...
cheers
Wow, nice headunit and Processor!!
I was using the Clarion DRZ9255 for a short while.
What are your mounting depth/diameter requirements? That would be a good place to start.
Where are you planning on mounting the drivers?
What do you feel is lacking in your Dyns?
What amps are you using?
cam2Xrunner
Postby joebxr » Fri Feb 24, 2006 4:31 am
What brand/model speakers? I'm curious onthe 8" especially
'06 Solara SLE V6
Arctic Frost/Dark Stone Grey
TRENZ Upper and Lower Billet Grilles
American Racng CASINO Polished wheels
SIRIUS Satellite Radio
joebxr
Postby Aotoyota » Fri Feb 24, 2006 9:25 pm
to answer some questions:
8" midbass dynaudio 180 or along those lines. depth is not an issue. everything will be custom but matched to the interior, thinking about kickpanels with the 3" tweet combo.
midbass and stage height
What amps are you using? currently Monolithics, soon to be Alpine PDX amps
then maybe 2 tens on the rear deck, 12's if i can fit them. [/quote]
Aotoyota
Postby Monkeyman » Mon Mar 20, 2006 7:44 pm
I have "Renaissance (formaly Morel USA)" 3 ways in my 2002 solara.
6.5" Midbass ( http://www.renaudio.com/carstereo/WR-6.htm )
2.1" Textile midrange ( http://www.renaudio.com/carstereo/MR-56.htm )
1.1" Silk dome tweeter ( http://www.renaudio.com/carstereo/triumph.htm )
3 way Crossover : ( http://www.renaudio.com/carstereo/XR-3.3.htm )
I guess you could call it a 4 way system because I also have a subwoofer: ( http://www.renaudio.com/carstereo/canon.htm )
The only way I found to add all three drivers without cutting holes all over the car, and still keeping a well defined soundstage was to put the mids and tweeters in the kick panels. Here is a link to pics of the kick panels I made with the mids and tweeters in place: http://www.solaraguy.org/viewtopic.php? ... highlight=
David
Monkeyman
Postby cam2Xrunner » Tue Mar 21, 2006 11:29 pm
You can have the Seas Lotus 8" made for you(they don't make them anymore) Go to www.mobilesq.com for a price quote.
Then get these
http://www.mobilesq.com/store/product_i ... ucts_id=36
and either the Aluminum or silk tweeters
http://www.mobilesq.com/store/product_i ... ucts_id=37
I'm running the 6.5" and the Aluminum tweeter. Best speakers I have heard to date.
For processing I am using an Eclipse CD8053.
For power I am using a pair of Arc Audio 2100CXL's- Vertically Biamplified.
Then for the substage I'm using a single Arc Audio Flatline 12D2 powered by an Audison LRx1.400
cam2Xrunner
Postby Aotoyota » Wed Mar 22, 2006 5:26 pm
thanks for the suggestions, i think i have decided (for now) on the dynaudio 8" with the alpine F1 mid ( scanspeak) and either the current dynaudio tweet or the alpine type-x tweeter (vifa)
sound like a monster but I put most of the components together and everything seems good.
thanks again.
:drinking:
Aotoyota
Postby drewbowski » Tue Jun 27, 2006 9:16 pm
Aotoyota wrote:to answer some questions:
[/quote]
its not dynaudio's fault you don't have imaging and install design plans layed out properly. more sound deadening and lower xover point for midbass, which will also increase your power handling. put the tweets in the sails to raise the stage. your sound is only as good as your install.
drewbowski
Postby vin » Tue Jun 27, 2006 9:21 pm
I'm running a 3-way,
Morel Ovation 4" in the kick panels and Morel MCW220 9" midbass speakers in the front doors. All I could say is that there's no need for subwoofers!
Powered by a Phoenix Gold Xenon X200.4 (200w rms x 4)
All in a `97 ES300.
`97 ES300: 18" Volk Racing "SS" wheels. Tein SS
vin
Return to A/V/N Gen 2 and 2.5
