SolaraGuy.com • View topic - hissing noise
hissing noise
hissing noise
Postby retarded » Wed Apr 19, 2006 10:04 pm
anyone using stock head units have a hissing noice comming out of your speakers when the volume is low? anyway i can fix that?
retarded
Postby Sap Z » Wed Apr 19, 2006 10:07 pm
i've noticed tht too..annoying
SapZ
V6 SE DWP
Sap Z
Postby data xXx » Wed Nov 15, 2006 3:59 pm
I noticed mine are hissing and it gets louder everytime I accelerate. I was told it was because I have a 4 channel amp and no aftermarket headunit so I'm getting feedback. You guys get the same type of hissing noise? gradually getting louder whenever the engine revs?
data xXx
Postby Sentinel » Wed Nov 15, 2006 5:12 pm
if the hissing is RPM dependent than you're getting interference from your spark wires / ignition coil. Try new plug wires.
Sentinel
Postby PXLpainter » Wed Nov 15, 2006 8:07 pm
Ask Python Josh - he might have an idea where the hissing is coming from! :o
:lol:
Postby tacti » Wed Nov 15, 2006 8:34 pm
yeah, when i had stock HU with 4 channel amp, i had the really bad hissing noise.
after i changed the HU to aftermarket, it reuduced the issue significantly.
however i still had some noise when engine rev up, so i tried the following and it worked great.
1. Get to the back of HU and find the grounding wire
2. get some bigger wire splice into it, then ground to the closest grounding point.
3. then run another wire from the grounding point alway back to the grounding point where battery negative is connected.
Also do Big 3 Up grade. I found this in SoundDomain, and it is really easy and cheap, and works really good engine whine problem, especially with aftermarket HU with 4 channel amp.
I used 2ga wire, and ring terminals
1) Add extra wire from Battery negative to the nearest grounding point. (there is one right by the battery where factory wire is)
2. Ground Alternator (I used one of the bolts on engine block close to the alternator) to closest grounding point.
3. Connect Alternator positive to the battery Positive. Make sure you add a fuse (I used 120A, but if you can find what the factory alternator out put, get a fuse that is a little bigger than that)
this will make the current flow better, and make it less whining noise (some people says that it will increase the HP, but I don't think so, and i didn't feel it).
if you go to SoundDomain forum and search for big3, you will find more information about it.
i am not 100% sure why it works, but i tried it, and it worked great for my car. as far as i know, better flow of current reduce the feedback to the HU.
I have some pics on my homepage, so please take a look and let me know if you want more pictures. i will put up more on request.
Tact
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby tacti » Wed Nov 15, 2006 9:14 pm
oops.. i checked my page and found that i don't have any picture.....
i'll put it up some time tomorrow...
<EDIT>
I updated my page and added some pictures under Solara>works>Big3 Upgrade.
it cost me only like $30 total, and less than 30 min of work.
i think it really worth trying if you are having problem with hissing/whining noise on your car...
RX-8 Page
Solara Page
SG Map
tacti
Postby Aotoyota » Sun Nov 19, 2006 6:40 pm
just some thoughts...
if you are using a line out convertor, most likely, the RCA's from the converter are in parallel with the power cable? seperating them as far as possible should take it all away. other thing could be the gain setting on the convetor may be too high and finding noise somewhere.
Aotoyota
Postby data xXx » Tue Jan 09, 2007 9:30 pm
I got the head unit changed to an aftermarket one and the noise is completely gone. but so are my steering wheel audio controls. so i guess ya win some and ya lose some... thanks for those who replied!
data xXx
Postby dvdchris45 » Tue Jan 09, 2007 11:59 pm
data xXx wrote:I got the head unit changed to an aftermarket one and the noise is completely gone. but so are my steering wheel audio controls. so i guess ya win some and ya lose some... thanks for those who replied!
Dont even get me started on steering wheel controls uugh...they sell a PAC-SWI adapter to get your steering wheel controls back. Maybe you'll have better results than I.
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Return to A/V/N Gen 2 and 2.5
