SolaraGuy.com • View topic - Kenwood KNA-G510
Kenwood KNA-G510
Kenwood KNA-G510
Postby Solara08861 » Wed Jul 12, 2006 10:35 am
I just installed the Kenwood KNA-G510 (navigation unit) its a hard drive unit made by Garmin for Kenwood. Installation was easy not like other Navs you don't have to connect anything to the transmission and engine bay. All you have to do is connected 3 wires to the radio. I have the KVT 715DVD Radio. The unit is nice and compact. Easy to navigate and if you need to upgrade the software or add more POI its done with a SD card.
Solara08861
Re: Kenwood KNA-G510
Postby Sebas007 » Thu Jul 13, 2006 4:40 am
I hesitate between the Kenwood setup KNA-G510 + any touchscreen and the Eclipse AVN-5495. I saw the Eclipse in action...may you post some pics of how it's looking in your car ?? Thanks
Solara08861 wrote:I just installed the Kenwood KNA-G510 (navigation unit) its a hard drive unit made by Garmin for Kenwood. Installation was easy not like other Navs you don't have to connect anything to the transmission and engine bay. All you have to do is connected 3 wires to the radio. I have the KVT 715DVD Radio. The unit is nice and compact. Easy to navigate and if you need to upgrade the software or add more POI its done with a SD card.
Postby Solara08861 » Fri Aug 25, 2006 9:51 am
Solara08861
Postby Sebas007 » Tue Nov 06, 2007 5:59 pm
What is the trim you have used on this pic ?? Do you think it can fit the Kenwood DDX-7019 ?? And where did you install the KNA-G510 ???
Funny to see I didn't change my mind that much from Jul 13, 2006 ! ;)
Postby Solara08861 » Sat Nov 17, 2007 10:48 pm
Seabs did you do the installation?
If so any pics?
Solara08861
Postby Sebas007 » Sat Nov 17, 2007 10:54 pm
Solara08861 wrote:Seabs did you do the installation?
If so any pics?
I've an appointment friday November the 23rd. I wanted to do it myself but I didn't found any place to do it...the temp is around 32F...doesn't want to freeze my fingers and work like crap.
I'll post pics of the install next friday ! :)
Postby Sebas007 » Sat Nov 24, 2007 11:13 am
I will solve the trim gap issue
For more info refer to http://www.solaraguy.org/viewtopic.php?t=36671
Return to A/V/N Gen 2 and 2.5
