SolaraGuy.com • View topic - '04 Firewall spot for amp wire
Postby SolaraDon » Mon Sep 25, 2006 9:15 am
As engine bays get more and more crowded it seems harder just to see the firewall. Maybe someone who has actually done this, or can see where an installer did, can help me out before I start taking things apart. I'm not afraid to do it, just want to know what direction to head in so, if you installed an amp, what route did you chose to run the power lead from the battery into the cabin? Is there an unused grommet, forced it in with an existing harness, or just drilled something new? Is there a route through the fender well like the hood release cable follows? Thanks.
SolaraDon
Amp Wire Routing
Postby jmpdmc » Tue Sep 26, 2006 6:29 pm
SolaraDon,
I just finished an amp install and used the hood release cable route. It seemed to work fine.
Jeff
jmpdmc
Postby SolaraDon » Wed Sep 27, 2006 9:16 am
Thanks. Everything is so crowded in the engine bay and behind the dash I was hoping for an alternate route to explore.
SolaraDon
Return to A/V/N Gen 2 and 2.5
