SolaraGuy.com • View topic - XM SkiFi unit and hum/noise
Postby Jack Soulfire » Thu Nov 23, 2006 4:42 pm
I recently hooked up a SkiFi (ver. 1 w/o FM transmitter) in my lara. It's tucked away nicely in the recess under the 3 climate control knobs in the middle dash. I've hidden all of the wires and hooked it up to my aux2car to run through my factory stereo.
My problem is that I'm getting a lot of high pitched hum & whining which sounds like a grounding issue and it's driving me crazy. I have a feeling it has something to do with the power coming from the cig lighter and then running sound out of the line out headphone jack on the unit.
I haven't tried using a cassette adaptor and can't try running FM through the radio since it doesn't have a transmitter. I'd rather not use FM or cassette for sound quality issues, but anything sounds better than what I have now. Am I screwed? I just paid about $140 for a year of service and don't want to waste it.
Some sound tech advice would be greatly, greatly appreciated.
2006 V6 Solara SE Sport
Jack Soulfire
Postby Jack Soulfire » Thu Nov 23, 2006 5:01 pm
I did a little more searching and found some info that states a ground loop isolator might remedy the problem. I may try to find one tomorrow and see if it works.
Jack Soulfire
Postby dougd4885 » Tue Nov 28, 2006 12:29 pm
hey, I just got one of these for my father and his 07 camry cause he the same issue with noise and a grounding problem.
http://www.crutchfield.com/S-QanNn0zAQp ... =127SNI135
2006 Solara SE
4 cyl. - 5 spd. auto
Oceanus Pearl w/ Ivory Interior
-Escort 8500 x50 radar detector (blue)
-USA SPEC Dual Aux. Input
-Sirius Starmate Replay ST2
dougd4885
Postby Jack Soulfire » Tue Nov 28, 2006 7:52 pm
I got a ground loop isolator from Radio Shack and it fixed the problem marvelously!
Jack Soulfire
Return to A/V/N Gen 2 and 2.5
