SolaraGuy.com • View topic - Ground Point
Ground Point
Ground Point
Postby mcsoccer7 » Tue Dec 19, 2006 6:30 pm
Anyone have a suggestion on where to ground my amps? They are going in the trunk, so a point in that vicinity would be great. Thanks.
mcsoccer7
Postby PXLpainter » Tue Dec 19, 2006 7:57 pm
Just keep diggin' 'til you find metal! :lol:
Postby unbalancedwood » Tue Dec 19, 2006 8:10 pm
in the tire wheel well, like an inch into the well, sand it down, drill it, screw it...
unbalancedwood
Postby mcsoccer7 » Tue Dec 19, 2006 9:18 pm
Is there anywhere that wouldn't require drilling? I can do it, it just makes me nervous drilling a new hole!!
mcsoccer7
Postby crispone » Tue Dec 19, 2006 11:04 pm
mcsoccer7 wrote:Is there anywhere that wouldn't require drilling? I can do it, it just makes me nervous drilling a new hole!!
Without digging into my own to pick a SPECIFIC spot... and with further EMPHATIC deference to safety as explicitly exempt as an onus risk to myself and all my holdings....
You can always use an M10 or M12 eyelet and pick a seatbelt anchor bolt or run your 4 gage to a front seat rear foot mounting bolt. SOLID ground, but you want to be very careful about compromising clamp load and design position secureness of intended equipment attachment.... (of course, you should file the "E-coat" or paint off to bare metal where your eyelet will seat.....
what do I know...
-crisp :evilbat: :drinking:
Postby PXLpainter » Tue Dec 19, 2006 11:55 pm
^^ Lemme guess... you stayed at a Holiday Inn Express last night? :roll:
Postby crispone » Wed Dec 20, 2006 4:27 am
PXLpainter wrote:^^ Lemme guess... you stayed at a Holiday Inn Express last night? :roll:
....hmmmm..... why would you say that? I was at a Motel 8, actually. 8)
-crisp :evilbat: :wink:
Postby RichD978 » Wed Dec 20, 2006 6:30 am
pull out on the carpet on the side of the interior behind the seats if you don't want to drill in the wheel well.
RichD978
Postby Solarafreek » Wed Dec 20, 2006 7:13 am
Just be careful not to drill into the gas tank...lol
Solarafreek
Postby mcsoccer7 » Wed Dec 20, 2006 7:51 am
Solarafreek wrote:Just be careful not to drill into the gas tank...lol
That's exactly what I was referring to!! That would be BAD!!! I think I'll dig around back there before I start drilling!!
mcsoccer7
Return to A/V/N Gen 2 and 2.5
