SolaraGuy.com • View topic - how to install rear speakers
Postby mluu510 » Mon Jan 15, 2007 8:13 pm
i bought PIONEER TS-A6961R 3-Way 6" x 9" Car Speaker for my solara.
http://www.amazon.com/PIONEER-TS-A6961R ... lectronics
how do i install them?
do i fold down the rear seats and remove the four black screws to reach the rear speakers? i read the solara repair manual. they want to remove so many stuff. i am pretty sure that's unnecessary.
mluu510
Postby mluu510 » Thu Jan 18, 2007 6:21 pm
come on, people. i know someone upgrade their system.
mluu510
Postby SolaraPete » Thu Jan 18, 2007 6:25 pm
No that manual is correct.
Use the "SEARCH" feature
SolaraPete
Postby woa_its_j3ff » Thu Jan 18, 2007 6:26 pm
sharp lookin speakers.
i have a gen 1 though.. so...
Postby anttarz » Thu Jan 18, 2007 6:27 pm
yea search, in gen 1-1.5 you got take out all the stuff behind the seats
anttarz
Postby mluu510 » Fri Jan 19, 2007 10:47 am
so i should let someone professionally install it? it cost $35 to get them to do it.
mluu510
Postby RichD978 » Fri Jan 19, 2007 10:53 am
mluu510 wrote:so i should let someone professionally install it? it cost $35 to get them to do it.
if its just $35 i would. but only if its $35. they might charge extra if $35 is only for basic labor. Make sure its a reputable place that has insurance in case they decide to take short cuts and eff something up.
RichD978
Postby funboy102 » Fri Jan 19, 2007 11:40 am
if you follow this guide right here, http://www.solaraguy.org/viewtopic.php?t=29372 , that's how to remove the rear deck to access the top mount for the rear struts, you can also access the speakers. As you see, it involves a lot of removing stuff, about 30-45 minute worth of labor, to take things apart and put it back together again, so it's up to you, $35 or DIY for 1-1.5 hours (including the time to install the speakers)
funboy102
Postby mluu510 » Mon Jan 22, 2007 10:52 am
funboy102 wrote:if you follow this guide right here, http://www.solaraguy.org/viewtopic.php?t=29372 , that's how to remove the rear deck to access the top mount for the rear struts, you can also access the speakers. As you see, it involves a lot of removing stuff, about 30-45 minute worth of labor, to take things apart and put it back together again, so it's up to you, $35 or DIY for 1-1.5 hours (including the time to install the speakers)
god damn it! that's so much work to do! why can't toyota make it easier to access common components?!?! i guess it's deter theft and another reason to option up for the jbl system.
mluu510
Postby netherland24 » Mon Jan 22, 2007 12:08 pm
it simple usually takes me roughly 45-hour to doo...
on camrys 97-01 remove rear seat bottom pops up and remove.
- the the sides u wii have 2 gold bolts that hold up the left and right side seat panels take them out and lift up and remove. the side panels on the pilars remove them they pop off and slide towards you
flip the seats down
take the 3 child locks off. and then i beleive pop the rear deck off and pull toward self and disconnect light. and there are ur 2 speakers 3 10mill bolts to remove. use a right angle and be careful not too slip and scratch ur tint or anythign.
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Return to A/V/N Gen 2 and 2.5
