SolaraGuy.com • View topic - Backup Camera install HELP
Postby automan » Wed Feb 28, 2007 9:24 am
I am in the process of install on 2004 Solara Convertable.
It has a flip open Nav Screen. I can't seem to got to the back.
Have console out. How to I get to plug in?????
The sourounding surface does not seem to pop-out like the console.
Can anyone help. Thanks Automan
automan
Postby Astro » Wed Feb 28, 2007 10:08 am
The console around the radio does pop out, just like the pieces around the shifter.
Postby rollaevo99 » Wed Feb 28, 2007 10:15 am
If not mistaken, cklinh has a back up camera install..... send him PM :D
Postby cklinh » Wed Feb 28, 2007 10:38 am
Not sure what exactly is the holdup... but check this thread...
http://www.solaraguy.org/viewtopic.php?t=15765
Look at the fourth picture... see those two brass nuts? You'll need to remove those as well as two others on top of the Navigation System to remove it. Then just look for the hole to insert your camera plug. You can't really tell by just feeling around in the back.
By the way, you will need to remove the gauge cluster on top of the navigation to access the two other bolts. Just get a good grip and give a good yank towards the back of the car, you should hear the clips releasing.
cklinh
Backup Camera Install 2004
Postby automan » Thu Mar 01, 2007 8:25 pm
Thanks - CKLINH, ROLLAV099, and ASTRO - You guys really saved me.
With out the info you guys gave me I would have been up the creek.
The camera is installed and looks and worls GREAT..
I ended up with the BEC 106 camera which works. Took pictures and will
post when I figure out how to do on the site. Again Thanks for all your help. Automan
[/img]
automan
Postby XEusioN » Sun Mar 18, 2007 11:32 pm
cklinh wrote:Not sure what exactly is the holdup... but check this thread...
Just curious, where did you place your backup camera? I stuck mine on my rear deck temporarily because I was lazy and it's pretty much useless there since it's a wide angle.
2005 Toyota Tundra SR5 V8
2004 Toyota Solara SE
7.1L - 12 Cylinders :: 442hp/488lb-ft
XEusioN
Postby PXLpainter » Sun Mar 18, 2007 11:44 pm
Hey - I'd really like to see some shots of your B-up cam installs guys! ;)
Backup Camera Mount
Postby automan » Mon Mar 19, 2007 7:26 am
I mounted mine in the middle of the backup lights - in the recess where the license plate goes, so it end uo right in the middle of the top part of the license plate. I was able to mount it forward enough to slide the top of the plate behind it. My Solara is black same as the camera and it looks and works great. I ran the wire through the same hole as the backup light power wires. Good luck with yours.
automan
Postby Truffles » Thu Mar 22, 2007 11:48 am
I'm seriously considering getting the BEC106 installed on my 2006 convertible.
I just want to find out though if there are other options I should consider. Are any of the license plate framed cameras any good? An installer told me they can pretty much adapt any camera to the back of the head unit that I currently have (OEM navigation)
2006 Solara Convertible
Cosmic Blue
Beige Top
Truffles
Postby Astro » Thu Mar 22, 2007 3:47 pm
Congrats on the install, I hope you enjoy it.
BTW, just make sure to keep an eye out, because anyone can just come by and rip it off.
Postby cklinh » Thu Mar 22, 2007 4:00 pm
XEusioN wrote:Just curious, where did you place your backup camera? I stuck mine on my rear deck temporarily because I was lazy and it's pretty much useless there since it's a wide angle.
cklinh
Postby XEusioN » Thu Mar 22, 2007 4:02 pm
XEusioN
Postby cklinh » Thu Mar 22, 2007 4:30 pm
^^^BTW, whatever happened with your guy R&D-ing ground wires for the Gen 2's?
cklinh
Return to A/V/N Gen 2 and 2.5
