SolaraGuy.com • View topic - Navigation Override
Navigation Override
Navigation Override
Postby mekaleka » Mon Mar 12, 2007 1:27 pm
Don't know if you guys have seen this, but...
Car Tip: Toyota/Lexus Navigation Override
How to operate the navigation & phone system override in many Toyota and Lexus vehicles. Once the Override is activated, the nav system and phone system can be operated while the vehicle is in motion. The system returns to its default settings each time the car is started.
Step 1 Press The Menu button
Step 2 Press the Volume button
Step 3 Press The Upper Left of the screen
Step 4 Press The Lower Left of the screen
Step 5 Press Upper Left of the screen again
Step 6 Press Lower Left of the screen again
Step 7 Press and hold the Override Button until system beeps
Step 8 Press Back Button in upper right corner
Done! The Buttons For Navigation & Phone are now accessible
Older Lexus and Toyota Systems may require a slightly different process:
Step 2 Press the System button
Step 7 Press The Lower Right of the screen
Step 8 Press and hold the Override Button until system beeps
Step 9 Press Back Button in upper right corner
Some versions may use the following steps:
Step 2 Press the DVD button
WARNING: Be safe - only use this when a passenger can safely input addresses or phone numbers. The service menu contains other options that should only be used by a Lexus or Toyota service professional. Do not attempt to access the service menu if you are not a Lexus or Toyota service professional.
mekaleka
Postby Down2TheC » Mon Mar 12, 2007 2:47 pm
Someone verify it works for Solara and I'll copy this to the tutorial section.
Down2TheC
Postby cklinh » Mon Mar 12, 2007 2:52 pm
Er... it works... I posted it a while back...
http://www.solaraguy.org/viewtopic.php?t=18909
cklinh
Postby Strapped4Cash » Wed Apr 11, 2007 9:44 am
Note: DVD version 6.1 or higher removes this entry point! The latest version that still supports it is 5.1. Some people have created a blended 5.1/6.1 DVD allowing them to have the entry point AND the latest map data.
2005 Lunar Mist SLE rag top w/NAV
Mike Ts Upper & Lower Grills
TRD FSTB & RSB
Eclipse BEC 105 camera
OmniFi MP3 Jukebox 80GB storage
Strapped4Cash
Postby cklinh » Wed Apr 11, 2007 10:41 am
Strapped4Cash wrote:Note: DVD version 6.1 or higher removes this entry point! The latest version that still supports it is 5.1. Some people have created a blended 5.1/6.1 DVD allowing them to have the entry point AND the latest map data.
If someone made it, then it should be available for download somewhere?
cklinh
Return to A/V/N Gen 2 and 2.5
Users browsing this forum: Majestic-12 [Bot] and 4 guests
