SolaraGuy.com • View topic - Navi install help
Navi install help
Navi install help
Postby dishon22 » Thu Mar 15, 2007 3:49 pm
What color is the “vehicle speed sensor” and “reverse gear signal” wires on the ECU.
dishon22
Postby dishon22 » Fri Mar 16, 2007 5:28 am
does anyone know?
dishon22
Postby XEusioN » Sat Mar 17, 2007 11:50 am
The VSS lead is Purple/White, and I'll check my FSM when I get home and see if I can find the reverse wire.
The manual for my D3 suggested I tap the wire at the actual reverse bulb itself...but thats a heck of a wire run because there is probably a wire at the shift assembly that has what you're looking for so I'll let you know what I find out.
2005 Toyota Tundra SR5 V8
2004 Toyota Solara SE
7.1L - 12 Cylinders :: 442hp/488lb-ft
XEusioN
Postby dishon22 » Sat Mar 17, 2007 4:42 pm
thanks
dishon22
Postby XEusioN » Sun Mar 18, 2007 9:16 am
Do you have an I4 or V6? Auto or Man?
XEusioN
Postby XEusioN » Sun Mar 18, 2007 9:30 am
Here's the chart for an I4/AT:
If you have an V6/AT:
The Reverse lead is in the same spot, but the VSS wire is on a different pin, it's E5-17 instead.
No clue on the manuals...
XEusioN
Postby dishon22 » Sun Mar 18, 2007 10:51 am
XEusioN wrote:Here's the chart for an I4/AT:
i got it working man thanks i have the v6 and there are a million wires connected to the ecu
dishon22
Return to A/V/N Gen 2 and 2.5
