SolaraGuy.com • View topic - P.CON wire - GEN2 JBL w/o NAV HELP!
Postby crispone » Sun Apr 01, 2007 3:47 pm
I have the complete wiring diagram... but can't seem to identify the right lead for P.CON (Power Connect) for my AMP "trigger" off the stock JBL (w/o navi) Head Unit.
Any suggestions?
(Is the P.CON a "momentary" trigger to switch the amps on??? I can't remember anymore...)
Note: I am "good" on the ACC switched lead...
Thank you,
Postby crispone » Tue Apr 03, 2007 4:42 pm
P.CON or REMOTE appears to be "constant on" voltage to switch a relay in the amps, precluding the potential for "speaker POP" upon power up/down... commonly "switched" by the HEAD UNIT on a system. (Ultimately, I didn't "FIND" it on the stock JBL... maybe it's there, but I went ahead with my OWN switch...)
An "independent switch" to dial "on/off" bridged to 12VDC from an ACC switched source works fine...
As for MY status NOW... well... that's another thread topic. 8)
Return to A/V/N Gen 2 and 2.5
