SolaraGuy.com • View topic - Avic-D3
Avic-D3
Avic-D3
Postby kpxboi0619 » Sun May 20, 2007 12:42 am
I'm getting the avic-d3 this coming saturday and just wondering if the steering wheel control such as skipping trakcs and volume works or not...
also I heard some people bypass the system so they could play DVD while driving... anyone know how to do that?
kpxboi0619
Postby cns » Sun May 20, 2007 6:41 am
yep... There is special cord that connected to your transmission, you have just make a short-circuit...
To talk a lot doesnt mean to tell a lot!
cns
Postby michaels artic frost » Sun May 20, 2007 8:38 am
If you want to retain your steering wheels functionalities, you'll need this
http://www.solaraguy.org/viewtopic.php?t=23070
As for watching dvd while you drive, most of the new HU requires a on/off switch to display video.
Good luck, I considered that unit once, seems like a good one.
-M 8)
Updated 06/01/12: Michael T's
Postby XEusioN » Sat Jun 09, 2007 2:12 pm
Hey I did the DVD bypass on my D3, it's fairly simple.
Ground the Green parking brake wire
Pull the yellow mute wire from the harness and insert it into the empty slot above it, ground that wire too.
That's it :)
2005 Toyota Tundra SR5 V8
2004 Toyota Solara SE
7.1L - 12 Cylinders :: 442hp/488lb-ft
XEusioN
Postby kpxboi0619 » Sat Jun 09, 2007 2:17 pm
oh~ thanx alot!!!!!!!!!!
kpxboi0619
Return to A/V/N Gen 2 and 2.5
