SolaraGuy.com • View topic - steering wheel controls
Postby modaman369 » Sat Jun 23, 2007 2:17 am
Does anyone know of any any headunits, or better yet A/V units that can be wired to the stock steering wheel controls?
modaman369
Postby cns » Sat Jun 23, 2007 10:42 am
There are some kits that can be used with your headunit in case if it has wireless control.
You can look this post to get more information about such kits
http://www.solaraguy.org/viewtopic.php?t=23070
or just look thru different developers of audio kits ect. http://www.pioneer.eu/eur/products/25/3 ... index.html
To talk a lot doesnt mean to tell a lot!
cns
Postby Aotoyota » Sun Jun 24, 2007 5:54 pm
PAC-audio is your best bet. they make a ton of stuff.
http://www.pac-audio.com/products/produ ... +Interface
Aotoyota
Postby Solara08861 » Mon Jun 25, 2007 10:22 am
I have the SWI-JACK with my Kenwood DDX radio
Solara08861
Postby KSolara » Mon Jun 25, 2007 10:45 am
I heard that eclipse makes the systems for toyota and that if u get an eclipse headunit u can connect the steering wheel controls directly
other than that PAC-audio
o4 SE I4 Lunar mist
KSolara
Postby theprodigy79 » Mon Jun 25, 2007 11:48 am
KSolara wrote:I heard that eclipse makes the systems for toyota and that if u get an eclipse headunit u can connect the steering wheel controls directly
That is false. The Gen 2 decks are made by Panasonic (even the "JBL" version). I'm not sure about Gen 1 though... Many Toyotas do have decks manufactured by Fujitsu Ten, the parent company of Eclipse, but that still doesn't enable aftermarket Eclipse decks to be compatable.
The steering wheel controls are hard wired from the factory, and very few aftermarket units have any receptical/wiring for such a connection, no matter what the brand.
The PAC control units splice into the steering wheel control wiring and send a signal to a remote eye located elsewhere in your car (in the case of the PAC SWI-X the signal can be programmed for any manufacturer). So, basically, it acts as a remote control and requires that your headunit is remote compatable...
If you have a headunit that is not remote control compatable, you're pretty much SOL...
theprodigy79
Return to A/V/N Gen 2 and 2.5
