SolaraGuy.com • View topic - Installing a subwoofer
Postby SHOLARA » Tue Aug 07, 2007 9:13 pm
I have a subwoofer and an amp right now. I want to connect my sub to my car. I preferably want to use the stock HU. Could someone help me with a tutorial to install this.
If I need another HU, I also have one. If you could let me know how to install this, it will be truly appreciated
Thanks in advance.
SHOLARA
Postby KSolara » Tue Aug 07, 2007 10:02 pm
hey.. its not that hard..
you are gonna need an aftermarket HU
basically:
-u run a power cable to the amp from ur battery positive with a 4 gauge wire or lower
-u ground the amp to a grounding pt in ur trunk
-Rca cables from ur headunit out to the amp
-power wire from the HU to the amp
-and speaker wire from the amp to the sub
run the power line from the battery on one side of the car and the power wire and rcas from the HU on the other side
I think thats about it explained really simply
o4 SE I4 Lunar mist
KSolara
Postby philosophicaljt » Wed Aug 08, 2007 5:20 am
or you can use the stock headunit, and just buy a piece that attaches to the rear 6x9's so that when ever the bass hits on the 6x9's the subwoofer hits also.
2004 Solara SLE V6
Search
philosophicaljt
Postby RichD978 » Wed Aug 08, 2007 6:34 am
^^ not recommended.
where are you located? If you're in the MA or NH area I can do it for you for a small fee
RichD978
Postby SC V6 » Wed Aug 08, 2007 6:35 am
sounds better with an aftermarket headunit, but works if you use the factory one...
SC V6
Postby SHOLARA » Wed Aug 08, 2007 5:39 pm
philosophicaljt wrote:or you can use the stock headunit, and just buy a piece that attaches to the rear 6x9's so that when ever the bass hits on the 6x9's the subwoofer hits also.
THanks for all your guys help, I'll see what I can do. When you say piece, what exactly is that piece.
SHOLARA
Postby NightRider » Thu Aug 09, 2007 1:27 am
Im in the same predicament. I have subs and a amp but no deck :( I know what I need to do but don't have that kind of dough to spend on a fancy deck that I like.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby philosophicaljt » Thu Aug 09, 2007 4:20 am
2004 Solara SLE V6
Search
philosophicaljt
Postby Jack Soulfire » Sun Aug 12, 2007 7:13 am
I was in the same boat as you and didn't want to buy an aftermarket head unit, so I bought a type-r alpine sub & alpine amp and hooked it up off my 6x9's with a line level converter.
Basically it sounds like total crap and I wish I didn't even have the sub hooked up at all now. Either wait until you can hook it up right to an aftermarket head unit, or don't do it at all.
That's just my 2 cents though.
2006 V6 Solara SE Sport
Jack Soulfire
Postby Traceur » Sun Aug 12, 2007 8:14 am
^^^ do NOT do that, waste of money and never sounds as good as just getting an amplifier hook up kit
even if you have to go to walmart
ive seen em go for 30$
and they have instructions in them
do you have the premium sound package?
Traceur
Return to A/V/N Gen 2 and 2.5
