SolaraGuy.com • View topic - CD text not on screen
Postby SKC » Sun Aug 12, 2007 9:30 pm
I have an 07 with navi/audio. I'm batting 0% on getting any CD titles to show up on the nav screen. I've played somewhere between 10-15 different discs, all store-bought, and no CD or track titles show up.
My XM titles show up just fine, and everything else within the system seem to work as advertised.
Any ideas?
SKC
Postby kedruff » Sun Aug 12, 2007 10:12 pm
CD-TEXT is rare, I've found. It's even quite complicated to create CDs w/ CD-TEXT support. You have to use Nero or RecordNow, iTunes, etc. doesn't support it.
If you want to test it, look for the CD-TEXT logo or create one using the aforementioned software. One of my Reba McEntire CDs supported it.
Cheers,
KD
kedruff
Postby SKC » Sun Aug 12, 2007 10:16 pm
Thanks.
SKC
Postby Mr. Slippery » Mon Aug 13, 2007 1:18 pm
You aren't missing much...
-MATT-
Mr. Slippery
Postby Chinky420 » Mon Aug 13, 2007 1:42 pm
^^ x2...the work:reward ratio for me wouldnt be worth figuring it out, but i'm sure the instructions at the top will put you on the right path
Chinky420
Postby SKC » Mon Aug 13, 2007 8:39 pm
I'm certainly not going to worry about it. I just wanted to insure that my system was operating normally.
SKC
Postby Frico » Mon Aug 13, 2007 8:52 pm
Try using a CD from Sony Music, either Columbia, Epic. Sony usually puts CDTEXT on their cds(store bought). Hope this helps.
Frico
Postby SKC » Tue Aug 14, 2007 7:35 am
That did it. I found a Sony disc and had all the titles. Not a huge deal, but good to know that it's working normally.
Spencer
07 SLE coupe
Magnetic Gray Metallic
SKC
Postby Frico » Tue Aug 14, 2007 4:47 pm
Sony will put CDTEXT on their cds but for some reason alot of the other record companies dont. It would be a nice thing if they all did it. Glad that worked for ya. HAPPY DRIVING!! :D
Frico
Postby NeFaRiOuS_SLE » Tue Aug 14, 2007 5:49 pm
Probably because not many appliances CAN decode CD-TEXT... So far the only thing that I've actually used that was able to was the OEM Toyota player (duh).
Return to A/V/N Gen 2 and 2.5
