SolaraGuy.com • View topic - removing door panel to change speakers
Postby randy » Tue Oct 02, 2007 8:07 pm
hey guys, can somebody please explain how to remove the door panels? I read up on here and did find some answers but I am still stuck at the "door handle" itself. everything is loose except the inside door handle/doorlock is stuck and i'm not sure if i am supposed to PRY it off, or if there's something i'm missing here. incase i'm confusing anybody, attached is a pic and in the red circle is where i'm stuck as to what to do. thank you very much! :D
randy
Postby kpxboi0619 » Tue Oct 02, 2007 8:22 pm
door handle thing opens up and there's a screw
and also the triangled shaped rubberish plastic thing that's covering the side mirror part from the inside, there's also a screw there
and when u pull the doors out, watch out for the wire thingy for the window button.
also when taking it off, push the door panel upward.
kpxboi0619
Postby NeFaRiOuS_SLE » Tue Oct 02, 2007 10:26 pm
I don't know about the Gen2 (99-03), but in the first generation after you remove the screw, you pad a flathead screwdriver with some masking tape, then stick it between the lock switch and the top, then the lever and the bottom.
Postby randy » Wed Oct 03, 2007 11:14 pm
thanks for the quick responses guys! i read them last night and was able to replace the door speakers, wire an alpine HU in my glove box (didn't wanna remove the stock deck) and ran my RCA's to the sub amp, and front speakers amp (both under the front seats). now just need to order a pac swi-x so i can leave my glove box locked and use the steering controls. thanks again. :D
randy
Return to A/V/N Gen 2 and 2.5
