SolaraGuy.com • View topic - Upgrading Headunit
Upgrading Headunit
Upgrading Headunit
Postby NightRider » Wed Oct 17, 2007 12:58 am
I just ordered a new alpine head unit the other day and it should be arriving next week. Anyways I have a couple of questions re: my situation. I already tried searching for my answers but no luck.
Where would be a good place to drill in through the firewall for my amp for my 4-gauge wiring to power my subs.
And second, I know my car has the JBL system in it and it has the amp to power them. I know it's probably pretty simple to bypass. Like what I did before in the same situation is that I spliced all the wires directly connecting it to the aftermarket headunit so all speakers can be amplified by the deck itself and completely cut-off the JBL amp.
Or do I have to run separate speaker wire from each speaker? Which I hope I don't have to right?
Any input/answers is greatly appreciated!
-Richard
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby NightRider » Wed Oct 17, 2007 1:00 am
Oops im sorry for posting this in the wrong section. I thought i was in the audio thread. If this can moved to correct section please! Thank you!
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby r0w » Wed Oct 17, 2007 4:18 am
Night, you should be able to use one of the existing holes in your firewall now just use one of those unless you really really wanna drill a hole that bad lol good luck bro, I was too scared to drill so I just found a existing hole on the passen. side :D
r0w
Postby philosophicaljt » Wed Oct 17, 2007 4:47 am
It really depends on your taste. From what I have read, the amp actually controls the sound logic in our cars, but I could be wrong.
If you want the absolute best setup, run new wires to each speaker. But that would be overkill to me. I just prefer loud clear sound. I am no competition junkie or anything.
Are you an audiophile? or just prefer a better headunit and some bass?
2004 Solara SLE V6
Search
philosophicaljt
Postby [SMAN] » Wed Oct 17, 2007 6:35 am
If you are not going to be running a new amp for your door speakers, use the existing amp. Metra makes a harness with RCAs so you can plug it right into your deck without needing to do a lot of splicing.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby NightRider » Wed Oct 17, 2007 10:35 am
Yeah but i want the deck to amplify the speakers.
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby NightRider » Wed Oct 17, 2007 10:36 am
philosophicaljt wrote:It really depends on your taste. From what I have read, the amp actually controls the sound logic in our cars, but I could be wrong.
Not too much an audiophile but I do appreciate superb sound in car audio 8)
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby NightRider » Thu Oct 18, 2007 12:27 am
[SMAN] wrote:If you are not going to be running a new amp for your door speakers, use the existing amp. Metra makes a harness with RCAs so you can plug it right into your deck without needing to do a lot of splicing.
See but I don't want to use the JBL amp, I want to use the deck to amplify my speakers.
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby redgen1 » Thu Oct 18, 2007 4:26 am
l know in my jbl system 1.5 that with my alpine h/u it does amplify the system... thinkin back to when i installed it this summer i def just used the exsisting wiring and spliced it. sounds great. i suggest tryin it first, im pretty sure that if you do it right it will be amplified with the h/u and not just the JBL stock unit
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby RichD978 » Thu Oct 18, 2007 5:44 am
find the amp and run the deck harness straight to the output wires
RichD978
Postby NightRider » Thu Oct 18, 2007 8:10 pm
RichD978 wrote:find the amp and run the deck harness straight to the output wires
Yeah good thinking! thank you!
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby crispone » Thu Oct 18, 2007 8:53 pm
^^^ I'd do SOME kind of replacement speakers... (the stock one's really are... well... LAME!)
...the AMPS are OPTIONAL... you can just go off the H/U, as well.
note: old skool amps... but they work.
^^^ Take the lead ends that I am NOT holding (RED, WHITE, BLACK, and YELLOW... that run out to the speakers...) and tap them from the H/U. (the stock JBL amp can be left alone...)
The PINK, GREEN, PURPLE and BLUE one's... would go to your head unit... for example... (seen in the background.)
...in my case, those are coming from my amps in the back.
^^^ Here's where you TAP through the firewall. There is ALREADY a large RUBBER BOOT that has a NIPPLE that you can "snip" and run your 4GA (or whatever) through. Try using "soapy water" or "armorall" (I don't like armorall) to "lube" the power lead so it "slides thru" the boot.
It will appear "readily" with the other large harness from up under the dash.
Good luck.
-crisp :evilbat: :drinking: (HOLY CRAP!!! I'm drinking HIGH LIFE!!! :o )
Postby philosophicaljt » Fri Oct 19, 2007 12:31 pm
^^wow. awesomeness.
2004 Solara SLE V6
Search
philosophicaljt
Postby RichD978 » Fri Oct 19, 2007 12:53 pm
crisp...boo to butt connectors and scoshe wiring hehh
RichD978
Postby NightRider » Fri Oct 19, 2007 5:31 pm
RichD978 wrote:crisp...boo to butt connectors and scoshe wiring hehh
Yeah thanks a lot crisp! I do appreciate your post.
And what's wrong w/ the connectors? No one will see them anyway haha
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Return to A/V/N Gen 2 and 2.5
